Hey guys,
so i have the Wilwood BBK on front.
I am missing one pad spring retainer clip.(the little ones that are on top and bottom of each pad)
Anyone know where I can get a new one? Or a 'fitting kit' similar to the ones available for oem brakes?
Stu
Wilwood Brake Parts
- MINX
Wilwood Brake Parts
- MattR
Re: Wilwood Brake Parts
Stu, if you have dynalite calipers then you should only need the bolt/pin through the caliper and pads. My wilwoods used a pin with a split pin. If you are using the equivalent to hb100 (hawk) pads then this will be all you need.
- MINX
Found them via an email to Emilio
Called Bridge Wear Plates
http://www.amazon.com/gp/product/B002G33N8A/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2IS69AN9A0OWP
Users browsing this forum: No registered users and 251 guests
