Adjusting rear swaybar
Posted: Fri Apr 12, 2013 6:59 pm
by sticky nicky
I am wanting to adjust my rear swaybar to soften it, its currently on the middle setting. I cant see how I can move the adjustable arm that goes up to the swaybay as it pivets the wrong way on the lower end for the front to back movement I need where it connects to the swaybar.
Its a whiteline swaybar and should be adjustable as it has the holes there.
Also when the two bolts are taken out of the swaybar, should I be able to rotate it in the bushes as it does want to move, maybe I need new bushes?
See pics below
Would appreciate some advice,
thanks Nicky
Re: Adjusting rear swaybar
Posted: Fri Apr 12, 2013 7:01 pm
by NitroDann
Just push harder, this is the only solution with stock sway links.
Posted: Fri Apr 12, 2013 8:15 pm
by manga_blue
Sometimes the only way you can do it is by bending the end links. I use a good vice and a small sledge hammer. The links themselves are tough as.
Posted: Fri Apr 12, 2013 9:17 pm
by project.r.racing
loosen the other bolt on the link.
Posted: Sat Apr 13, 2013 12:20 pm
by sticky nicky
Ok, thanks for your help guys :D
Posted: Wed Apr 17, 2013 9:32 pm
by evil_weevil
Sorry to hi-jack thread, but I had an issue ages ago with my front whiteline sway bar, nothing I could do would get it into the hardest setting, only the middle one.
would this help?
http://www.mx5mania.com.au/product659.htm
Posted: Thu Apr 18, 2013 2:04 pm
by project.r.racing
yes as the rose joints allow more flexability with angles.
Posted: Fri Apr 19, 2013 3:46 pm
by evil_weevil
ah fantastic!
now, wheres the cheapest place to buy from hah
