NA8 brake squeak
tooch
NA8 brake squeak
Postby tooch » Mon Mar 25, 2013 12:12 pm
Hey all,
Got an annoying squeal coming from my (front?) brakes. It's not the typical high pitched metal on metal sound that you get when brakes are worn, it's a loud squeak. It only really happens at low speeds when lightly applying brakes, such as when crawling along in traffic.
I don't believe the pads/rotors are worn out, but could it be maybe that the pads are no good? Any other ideas?
Simon
Re: NA8 brake squeak
Postby manga_blue » Mon Mar 25, 2013 12:28 pm
Small stone jammed between the disc and the stone shield or caliper?
tooch
Postby tooch » Mon Mar 25, 2013 9:09 pm
Hmm good suggestion that, I've had it happen before on another car!
I've got a day off work tomorrow, might pull the wheels off and take a look.
