Question about FM butterfly brace and road worthiness
Re: Question about FM butterfly brace and road worthiness
Postby KevGoat » Sat Mar 23, 2013 4:41 pm
Hey there ... welcome :)
Can't help with the roadworthy question with the braces fitted, but regarding the ride quality, if you can give some more detail of your car's suspension setup and components, there's bound to be advice that could help improve the comfort and probably handling at the same time.
From your explanation it sounds like there are other issues more than just a flexing chassis.
Steampunk
Postby Steampunk » Sat Mar 23, 2013 6:01 pm
jamsbong wrote:.. they replied that my car will not be road worthy after installing the part because holes have to be drilled into the car and may adversely affect the car's stabiliy and thus safety...
Sounds like yet another idiot mechanic.
Does he not realise that the holes are being filled with bolts and nuts and stuff.
you have to drill holes for Rollbars and they get complied everyday, go find a place that does compliance plates, perhaps a 4WD/truck/caravan place, and talk to an ENGINEER instead.
project.r.racing
Postby project.r.racing » Sat Mar 23, 2013 6:04 pm
bingo, above post just said it. if you have to drill into the chassis, then it will effect roadworthyness. getting it complied would be a requirement. but there'd be plenty of assessors that you past a chassis bar or frame without a plate.
sailaholic
Postby sailaholic » Sat Mar 23, 2013 7:02 pm
It's only in tho the floor not not any of the rails. And it's obviously a big ass chassis brace. I'd say they are a numpty or going with the safe answer.
outbreakmonkey
Postby outbreakmonkey » Sat Mar 23, 2013 7:31 pm
Sounds more like rooted shockers to me. Either that or you're just used to driving soft shopping trolleys.
Steampunk
Postby Steampunk » Sat Mar 23, 2013 9:03 pm
jamsbong wrote:I have not test drove another nb1 so i am not sure if this is normal.
I will goto a 4WD mechanic and ask the same question.
You do know about the "scuttle shake" on MX-5's don't you? if not then google it.
Don't go talking ANOTHER mechanic, talk to an ENGINEER, world of difference. I mentioned 4WD/truck/caravan places because they do a heap more chassis mods than your usual car places.
de Bounce
Postby de Bounce » Sun Mar 24, 2013 6:50 am
IMHO start with the basics like tyre pressure and a proper alignment, while it is being aligned ask them to check the shock.
There are a lot of NB8A's that don't have the butterfly brace and appear to travel along quite well
Might be worth dropping into the Garage on a Thursday night.
Let some of the regular MX5 people have a look before blowing your money on a perceived problem.
Motorkhana Video
Postby KevGoat » Sun Mar 24, 2013 11:39 am
Another consideration to check out the issues with your car's ride is the Pedders suspension test. Although the cost has doubled recently to $28 (can't believe the amazing $14 cost they stuck with for so many years!) I have found it a great source for information on how my suspension components are holding up. They have never pressured me to do any of the work required, though I have often used them and have always been very happy with the quality of their components and services.
I have absolutely no alliance with them, just a very happy customer over many years and many cars.
Postby 93_Clubman » Sun Mar 24, 2013 12:04 pm
Dec 2012 Vicroads Roadworthiness Requirements VSI - see page 8:
http://www.vicroads.vic.gov.au/NR/rdonl ... 12_WEB.pdf
Oct 2011 Vicroads modification guide - see page 2, para 4 & page 4, para 9:
http://www.vicroads.vic.gov.au/NR/rdonl ... hicles.pdf
Superseded versions of the above VSIs are near the bottom of this page & might provide more detail as Vicroads appear to be streamlining some newer VSIs:
http://www.vicroads.vic.gov.au/Home/Saf ... mation.htm
Postby NitroDann » Sun Mar 24, 2013 12:42 pm
I bet its a setup issue or worn parts.
that our you are used to driving boats.
Wivvix
Postby Wivvix » Sun Mar 24, 2013 7:09 pm
What you are describing doesn't sound right for an NB.
I'd get things looked at by a mechanic who knows mx5s. See if you can find one through this forum.
If you do decide to go down the FM brace route, I suggest getting the frame rails alone. The butterfly brace helps but it's also a pain and significantly complicates the install, and fitment issues with cats and exhaust pipe.
Aside from that you could also look at the other usual culprits, i.e. wheel bearings, suspension bushings, bent a-arms, tyres, shocks/springs etc.
sailaholic
Postby sailaholic » Sun Mar 24, 2013 8:14 pm
If you only go the rails there is a local Australian made version. Have a look at omgpham.com who is a site sponsor.
MattR
Postby MattR » Sun Mar 24, 2013 9:35 pm
Get the simple things checked first before spendinng your money.
The pedders check at $28 is good value, or take it to one of the MX5 specialists in Melbourne, check out the forum sponsors to help you choose who to see.
I reckon it will be somethonng pretty simple, could even be as simple as tyre pressures, as the 5 seems fairly sensitive to pressures. After that just work through simple things that can be checked by visual inspection, such as tyres, bushes, do the shocks leak, any damage to mounts,bent arms and so on and then move onto the harder things to check like alignment.
de Bounce
Postby de Bounce » Tue Mar 26, 2013 5:43 am
jamsbong wrote:This sounds like a good idea. Also, I'm keen to meet other MX5 enthusiast. Where can I meet you ppl?
I live at West Footscray.
The Garage Cafe is at 221 Berkeley St. Carlton, we meet every Thursday from about 6:30 till Robin kicks us out.
There is a thread on here http://mx5cartalk.com/forum/viewtopic.php?f=64&t=17056
Motorkhana Video
sailaholic
Postby sailaholic » Thu Apr 11, 2013 7:07 am
WhAt if all he does is the vass and you do the rest. Install wouldn't be cheap.
