BFG g-Force Rival - The new "IT tyre"?
Posted: Wed Jan 30, 2013 1:42 pm
FYI for those on the lookout for their next tyres:
BFG has introduced a new "g-Force Rival" tyre that is supposed to "Rival" Hankook RS3s and Toyo R1Rs but has a Uniform Tire Grade Quality (UTQG) of 200 vs 140 for the latter 2 tyres which means that the Rivals will wear better, making them more suitable for everyday driving.
Andy Hollis (Post#18) gave a very favourable and unbiased view here: http://forum.miata.net/vb/showthread.php?t=487779&highlight=BFG+Rival
See http://www.tirerack.com/tires/tires.jsp?tireMake=BFGoodrich&tireModel=g-Force+Rival&sidewall=Blackwall&partnum=05WR5GFR&tab=Specs for Tire-Rack specs.
Product Description (from Tire Rack):
The g-Force Rival is BFGoodrich’s Extreme Performance Summer tire developed for sports car, muscle machine and pro-touring car driving enthusiasts who want their tires to turn heads on the street and lower lap times at the track. Created with razor-sharp reflexes, the g-Force Rival is designed to raise the limits by delivering extreme grip that’s extremely predictable. However, like all summer tires, it is not intended to be dríven through snow, on ice or in near-freezing temperatures.
g-Force Rival tires feature a Silica-infused compound molded into asymmetric tread designs that are performance-tuned to match tire width (255mm and narrower sizes feature a 3-rib design, while 265mm and wider sizes use a 4-rib pattern). Large, solid outboard tread blocks and BFGoodrich’s Extreme Tread Edge (ETE) shoulder design wraps the tread compound farther down the sidewalls for predictable feedback and maximum cornering grip from start to finish. Lateral groove draft angles promote consistent performance and wear, while chamfered block edges resist feathering under extreme cornering and braking.
The tire’s internal structure features BFGoodrich’s Performance Racing Core reinforced internal structure that reduces flex to increase steering response. The tread is stabilized by twin steel belts and an Equal TEnsion Containment System (ETEC System) of spirally wrapped nylon to optimize the tire’s contact patch and traction at speed. g-Control sidewall inserts tune the sidewall stiffening to promote steering response.
