15x9 6ul on a na6 any issues?
peterwho
Postby peterwho » Wed Jan 23, 2013 2:54 am
im planning to purchase a set of 15x9 6ul's from 949 racing, ive got yellow speed racing dynamic pro coilovers. I understand you have to roll and even pull the fenders (already rolled) but is there any need of spacers to avoid rubbing with my springs? has anyone on here had or have this set up? thanks in advance :)
sailaholic
Re: 15x9 6ul on a na6 any issues?
Postby sailaholic » Wed Jan 23, 2013 6:28 am
6uls are designed for a mx5 right up to 10 inch. You shouldn't have any problems fouling things on the inside only fitting them under your guards.
hb
Postby hb » Wed Jan 23, 2013 7:28 am
from my understanding 15x9s rub on the standard suspension but with a narrower setup like your yellowspeeds youll be fine
ginger bread man
vrmmmpshhh
Postby vrmmmpshhh » Wed Jan 23, 2013 8:30 am
what are the offsets on the 15x9
Apu
Postby Apu » Wed Jan 23, 2013 8:31 am
Is your engine stock? I'm just wondering why you'd go 9 inch. If you're doing for stance/looks etc, that's your choice but just wondering if you're aware of the downsides.
project.r.racing
Postby project.r.racing » Wed Jan 23, 2013 8:57 am
vrmmmpshhh wrote:what are the offsets on the 15x9
offset are all +36mm for all 15 inch 6ULs except the 7.5 wide option, that is +42mm
lightyear
Infinity & Beyond
Postby lightyear » Wed Jan 23, 2013 9:04 am
I run 15x9" 6ul wheels with 225/45/15 tyres on my NA. They don't hit on my car, and I only have a light guard roll.
Users browsing this forum: No registered users and 270 guests
