Sway Bar Problems Help Needed - didn't pass rego
ondman88
Vehicle: NA6 - Supercharged
Postby ondman88 » Wed Jan 16, 2013 8:54 pm
Hello Every one,
I failed rego on my sway bars not being wide enough. So I ordered new sway bars and and it seems to be the same storry with the rear one.
Without having the link pins on a angle slash bent they will not work.
Wondering if it is normal for the link pins to be on an angle and not sraight up and down?
I am kind of lost and I only have till Friday the 18 of January to fix it.
Any information would be much appreciated.
Regards,
Andre
1990 NA Mx5 1.6 Supercharged British Racing Green
Mx5 Best Value for money car ever.
Re: Sway Bar Problems Help Needed - didn't pass rego
Postby NitroDann » Wed Jan 16, 2013 8:59 pm
Tell the mechanic to get bent. he is an idiot.
bigdog
King of the kennel
Postby bigdog » Wed Jan 16, 2013 9:30 pm
Take it to an intelligent mechanic - that's the way they were made. The angle of the link means nothing. And make him pay for the replacement sway bar too!
Steampunk
Postby Steampunk » Wed Jan 16, 2013 9:37 pm
Initially reading OP it does seem like the mechanic is an idiot but if you think about it, it's actually not that bad and he's just a little ignorant.
Firstly, it would help to tell us what model car you have.
Secondly, assuming it's an NB, I theorise that the mechanic has seen a fair number of NA front anti-sway bar which has the end sections parallel to north-south, and with this in mind, he looked under your NB and saw that it's on an angle and incorrectly assumed you bent it out to fit.
Did he make a comment on the rear one or are you assuming he would?
Rear NA & NB anti-sway bar are pretty much identical.
If my above assumptions are wrong, then yes, mechanic is an idiot.
ondman88
Postby ondman88 » Fri Feb 15, 2013 7:12 pm
It's a NA6 actually. The mechanic was an idiot and I should have taken it else where but its done now.
I haven't stopped having troubles with the new sway bar though as the link pin bush keeps pulling out of the link pin. I'm going to take it back next week to the suspension place that have now seen the car two times already.
If they don't properly fix it this time I'm going to loose my calm big time.
I'm going to tell them I'm not paying for their time this time.
Fingers crossed it all gets fixed.
If anyone on the forum is willing to take a look in the ACT I'm happy to meet them some where etc?
Postby NitroDann » Fri Feb 15, 2013 7:27 pm
Tell em where you live son.
Tony
Postby Tony » Sat Feb 16, 2013 8:35 am
Take it to either ACDC in Mitchell or Carco in Belconnen.
'09 NC2
ondman88
Postby ondman88 » Sat Feb 16, 2013 12:44 pm
I took it back to the suspension place for them to try and fix it again.
I'm in Curtin but the car is currently in Philip now.
Ill get it back Monday and if its not fixed properly I won't be happy.
Ill send you a private message about help nitro dann.
Users browsing this forum: Google [Bot] and 291 guests
