New shocks & springs?
A lot of people here (myself included) are running Koni adjustable shocks with various springs. Koni & King are a popular combination. I opted for Mazdaspeed springs, but I reckon they're a bit on the soft side. They make for a damn comfortable ride, though.
EDIT: I should also note I got my Konis from shox.com for ~$650 shipped
Rear Springs on 1990 NA
- lee
Re: Rear Springs on 1990 NA
'91 Roadster
- bensale
The problem you'll be having is that when the shocks compress you're hitting the rear bump stops. It's a fairly common problem with lowered MX5s particularly the NA series and can cause some really nasty characteristics, especially when combined with worn out suspension. The Koni's are a good option for reasonable money as well as a number of coilovers which start at around $1000. Also look into the FatCat motor sport bumpstops which are shorter and made of progressive rate rubber.
www.othersideproductions.com
- lee
Ian Thomas wrote:MX5 CAR TALK is better than most of the international classic and collectable sites.
You've picked it on a good day
Ben's advice is very good. With good quality components, a couple of little mods can work wonders for our little roadsters.
Good to hear you're enjoying the car!
'91 Roadster
