NB8A wheels - how to remove centre caps?
- travis
I realise this is a completely newbie type question. I want to remove the centre caps to do some painting but there does not seem to be a an obvious method of doing so. My previous car had a recessed section on the wheel nut covers, to place a screwdriver and simply pry it out. Is there a particular spot on the NB8A wheels? Or will anywhere do? Thanks.
Montego Blue NA8
- davekmoore
Re: NB8A wheels - how to remove centre caps?
Would it be remove the wheel then tap the centre cap through?
- Dweezle
I just grab it and pull hard.
I do the same with the centre caps.
maybe mine are looser than most??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Jeremy Clarkson
- Steampunk
Dweezle wrote:I just grab it and pull hard.
maybe I'm looser than most??
AHA! I KNEW there was something suspicious about you!
- Dweezle
Jeremy Clarkson
Jeremy Clarkson
You didn't say what type of rims you have.
Enkei caps have a metal spring-clamp that locks them in place from the inside of the wheel and you need to pry that off to pop out the cap.
Spend a few minutes doing this first, it might save your caps.
If they are just the stock wheels, place a flathead screwdriver between the cap and wheel and place some leverage on each of the four points. They should pop right out (I just tried this method on mine; it took 10 seconds to remove one cap).
- travis
Both the title and my text clearly states NB8A wheels.... Anyway, I appreciate everyone's input. Thanks.
- Vehicle: Non MX-5
just push them from the inside out. any kind of rod, stick it through the hub nut hole in the wheel, hit rod with hammer.
project.r.racing wrote:just push them from the inside out. any kind of rod, stick it through the hub nut hole in the wheel, hit rod with hammer.
Yeah, I use the opposite end of a hammer to knock them out.
- Vehicle: Non MX-5
yeah i just use the end of the hammer handle also. but i was assuming they must have been stuck in good if they warrented a post and the answers people were giving.
