BRIDGESTONE S001's
Posted: Fri Oct 05, 2012 8:53 pm
by taminga16
Hi,
Per thread title, has anyone had experience with these tyres.
Thanks.
Greg. (NC2 205/45 17")
Re: BRIDGESTONE S001's
Posted: Sun Oct 07, 2012 8:28 am
by Charlie Brown
Sorry no.
I got a set of Michelin Pilot Super Sports from Tire Rack. Landed and fitted for around $1,050.
Ranks No. 1 in the tyres tested.
Posted: Sun Oct 07, 2012 8:37 am
by SilvRFoxX
Charlie Brown wrote:Sorry no.
What does it then cost to get them fitted, balanced and aligned?
Posted: Sun Oct 07, 2012 9:18 am
by sailaholic
Fitting and balancing is usually 15 to 20 a tire. Alignment is often best done by someone other then a tire store. 80 - 100
Posted: Sun Oct 07, 2012 9:24 am
by SilvRFoxX
sailaholic wrote:Fitting and balancing is usually 15 to 20 a tire. Alignment is often best done by someone other then a tire store. 80 - 100
Thanks.. do the tire places get funny because you supply your own tires..?
Posted: Sun Oct 07, 2012 9:52 am
by jorgan92
SilvRFoxX wrote:sailaholic wrote:Fitting and balancing is usually 15 to 20 a tire. Alignment is often best done by someone other then a tire store. 80 - 100
They shouldn't charging you $15-20 a tire would mean they would probably make more profit that way then they would on a cheap set of tires anyway.
Posted: Sun Oct 07, 2012 10:10 am
by 93_Clubman
Cost me $100 to get 4 tyres removed from my NA6 rims & fitted to my NA8 rims back in '04 - was in Canberra, so reasonably captive market.
Posted: Mon Oct 08, 2012 2:07 am
by Gmi
I've used them on my civic ages back. It's a quiet tire compared to re001s and better grip in the wet; dry around the same. But I'm no racing driver.
On another note, I thought they stopped making s001s? Would be good to check when they were made.
Posted: Mon Oct 08, 2012 8:25 am
by 16bit
they only started making them last year. doubt they are going to stop. they were released with the re002's
Posted: Mon Oct 08, 2012 8:41 am
by taminga16
Gmi wrote:I've used them on my civic ages back. It's a quiet tire compared to re001s and better grip in the wet; dry around the same. But I'm no racing driver.
As 16 bit says they are a new tyre and are a replacement for the 050's, atm the 050 is only available in 205/45 17 in RFT and in time more sizes will disapear from the range.
Greg.
Posted: Mon Oct 08, 2012 5:46 pm
by Gmi
Ah. I might have remembered incorrectly then. Might have been re050 or even 040.. Since it was 5 years ago :S
No input then.. My bad.
