Solution to overheating tyres and brakes
davekmoore
Postby davekmoore » Tue Aug 07, 2012 10:05 pm
So, largely thanks to Craig for showing me how to go quicker at Winton on the Racecraft day on Saturday, I'm now finding my Yokohama road tyres going off and the slotted RDAs making groaning noises while going very slowly back to the pits after 10 laps.
With the tyres at normal temps the set up is for no understeer and oversteer only if I'm really stoopid or super brave. There's defo a bit of tyre induced understeer from around lap 5 and plenty of tyre induced oversteer from lap 4. From then, unless I slow down, it goes differently around each corner with random combinations of understeer, oversteer and four wheel drifts. All good fun but way slower. The brakes seem fine when on the track for 10 laps but I wonder if I'm doing them any harm - and I guess the hot brakes contribute to the hot tyres?
So no doubt I'm now on the next slippery slope of throwing money into the pit and could use some advice of what to do next ......
Swap the 17 x 7s for 15 x 8s or 9s to get wider tyres with more grip but less heat?
Or put bigger front brakes on so they get less hot but then have to have 16s or 17s?
Or different tyres, bearing in mind the car is still my DD?
More air to the brakes by losing the fogs - or by other means?
Other ideas?
Re: Solution to overheating tyres and brakes
Postby NitroDann » Tue Aug 07, 2012 11:20 pm
davekmoore wrote:Swap the 17 x 7s for 15 x 8s or 9s to get wider tyres with more grip but less heat?
Hjt
Postby Hjt » Wed Aug 08, 2012 12:27 am
Two sets of tyres makes a massive difference, because what is good for your DD sucks on the track. You will always be limited by trying to compensate for both.
Your current brakes should be fine, if anything get some s/s braided lines and good pads/fluid.
Confidence in braking helps improve your lap times.
Postby NitroDann » Wed Aug 08, 2012 12:36 am
Hjt wrote:15'' tyres makes a massive difference, because what sucks for your DD sucks on the track. You will always be wanting to get rid of your 17s, cuz.
FTFY
Hjt
Postby Hjt » Wed Aug 08, 2012 8:59 am
I have 15x7 and 15x9s. I do agree with the above. But if your budget doesn't allow, just change the track wheels and keep the DD wheels.
Zcootz
Postby Zcootz » Wed Aug 08, 2012 9:42 am
FTFY???? What does that stand for ?
With two laps to go then the action will begin, unless this is the action, which it is.
Murray Walker
Charlie Brown
Postby Charlie Brown » Wed Aug 08, 2012 9:53 am
I agree with Hayden. You’ve reached the point that we all get to in our motor sporting life where road tyres just don’t cut it, unless you’re running in the stock class.
Change up to an R-spec tyre and a rim width that is compliant with your class rules. 15" tyres are cheaper than 16".
Going to R-specs will allow for better braking (as well as cornering) but this will then fry your pads unless you get dedicated track pads and rotors. Never ending forking out of money in motor sport, eh. :roll:
MINX
Postby MINX » Wed Aug 08, 2012 10:57 am
Solution -
DD to Track car in under 15mins
Postby hks_kansei » Wed Aug 08, 2012 11:10 am
The cheapest way is to just do a cooldown lap after every 3 laps.
Unless you're actually racing (and not just doing a trackday setting laptimes) there's no point to force teh car to do 5laps straight and cook the tyres and brakes.
Postby hks_kansei » Wed Aug 08, 2012 11:11 am
Zcootz wrote:FTFY???? What does that stand for ?
Fixed That For You
Postby NitroDann » Wed Aug 08, 2012 11:16 am
http://lmgtfy.com/?q=FTFY
timk
Postby timk » Wed Aug 08, 2012 11:18 am
Stu, do you use the rattle gun with the 949 lug nuts?
Zcootz
Postby Zcootz » Wed Aug 08, 2012 11:52 am
Fixed That For You
Cheers, man I'm feeling old, nearly had to ask my 13 year old son that. You saved me. Lol
Murray Walker
MINX
Postby MINX » Wed Aug 08, 2012 11:53 am
saboteur wrote:Stu, do you use the rattle gun with the 949 lug nuts?
Yes
But i dont rattle them on hard - i use a torque wrench to make sure they are even
That Ryobi rattle gun is very easy to controll speed
Postby Lokiel » Wed Aug 08, 2012 12:01 pm
I have the same setup as MINX and use the rattle gun to remove the 949 Alu lug nuts but NOT to tighten them, I do that by hand + torque wrench.
Previously I had a demonic Ozito rattle gun that only had two speeds, OFF and ludicrously-ON - if I used it to tighten the wheel nuts, they would be permanently welded onto the rim (it's now safely locked away to prevent potential devastation to all of humanity).
The Ryobi rattle-gun speed is more controllable but I'm still having nightmares about the Ozito rattle gun so prefer to tighten the Alu lug nuts by hand.
