Short life on a wheel bearing
mitch_f1
Postby mitch_f1 » Thu Jun 28, 2012 10:49 am
So it looks like my front drivers side wheel bearing is gone now (it has play when I pull the wheel side to side, but not up and down). It was replaced 2 years ago by Mania, and barely has 10,000kms on it since then. Is it normal for a wheel bearing to have such a short life. Could this be symptoms of a bigger problem?
Re: Short life on a wheel bearing
Postby NitroDann » Thu Jun 28, 2012 10:54 am
Could be tie rod ends.
mitch_f1
Postby mitch_f1 » Thu Jun 28, 2012 10:56 am
They are similarly new, and with someone pulling on the wheel I could feel no movement at the TRE
Postby Mr Morlock » Thu Jun 28, 2012 11:10 am
Wheel bearings can have a signficant life- decades. Many wheel bearings are adjustable-not sure about MX5 - someone will know. If its convenient return it to the contractor for proper diagnosis.
Pamex
Postby Pamex » Thu Jun 28, 2012 11:11 am
There was a bad batch of aftermarket ones going round a year or so ago. Could it be one of those? Or did you go genuine?
mitch_f1
Postby mitch_f1 » Thu Jun 28, 2012 11:17 am
It was a genuine, as stated on the Mania invoice.
I called Ajay, and he said there wasn't anything he could do for 2 reasons; the 12 month warranty on new parts (been 24 months since install), and the car has seen track work.
deviant
Postby deviant » Thu Jun 28, 2012 11:29 am
mitch_f1 wrote:It was a genuine, as stated on the Mania invoice.
What other modifications have you made in the suspension department?
Crazy alignment specs?
What tyres do you use and how often have you been on track?
mitch_f1
Postby mitch_f1 » Thu Jun 28, 2012 11:49 am
Yes to all of the above. BUT, the passenger wheel bearing is still the original one (AFAIK; certainly not ever been replaced while in my hands), and it is doing fine!!
Postby manga_blue » Thu Jun 28, 2012 11:56 am
Not much you can do about it except ask for a discount from Mania on replacing it again. Track work is not as hard on wheel bearings as driving on most of our public roads.
Genuine means that Mania bought it from Mazda who bought it from some guy in Malaysia and put a Mazda bag around it. He bought it from a small workshop in Thailand who got the castings from a foundry in Laos and the bearings from ebay Hong Kong etc, etc, ... but the important thing is that it fits when it's first bolted on. :roll:
myredmx5
Postby myredmx5 » Thu Jun 28, 2012 12:10 pm
manga_blue wrote:Not much you can do about it except ask for a discount from Mania on replacing it again. Track work is not as hard on wheel bearings as driving on most of our public roads.
Just wondering does this packaging constitute as being a genuine Mazda part? It says Made in Japan.
A.Chen89
Postby A.Chen89 » Thu Jun 28, 2012 12:16 pm
Were the genuine Mazda ones really expensive?
I've had one out of two after market wheel bearings fail after a few hundred km's (not NTN or Tinken). Maybe it was from a bad batch.
Replaced the failed one with an NTN one and it's been fine still after a few track days.
I am here: http://tapatalk.com/map.php?pa1jp1
Postby manga_blue » Thu Jun 28, 2012 12:53 pm
I'd be confident with that one.
Postby Mr Morlock » Thu Jun 28, 2012 1:58 pm
take it back to AJ and get it checked to find the root cause. Certainly in normal service it should last many years. Whilst the warranty is expired you may still get a discounted price on the parts for re supply if the bearing is faulty. No one commented if the bearing is adjustable- they are on many vehicles. People refer to bad batches but this is really a bit of a misnomer. Whilst it can happen a quality bearing is going to have a very low failure rate- measured in parts per million. Consider every car is full of bearings and failure of a bearing can be very expensive so they are made and process controlled to last often for the life of the car.
Pamex
Postby Pamex » Thu Jun 28, 2012 2:02 pm
Cheyne may have some info too, I think he had 2 or 3 dodge ones in a short period (weeks, I think), both genuine and aftermarket. Could be wrong, but he may be able to shed some light.
Regardless, I agree. See what Ajay can do.
mitch_f1
Postby mitch_f1 » Thu Jun 28, 2012 4:25 pm
Interestingly I no longer think it's the wheel bearing. I pulled the wheel and rotor off and had a good tug of just the bearing (only recently reacquired a 21mm socket; lost my old one, so couldn't remove the wheel before hand), and it's fine. I grab the tie rod itself and pull and I get the same noise. So now my question is, apart from the tie rod end, what else wears out in the steering. Does the joint on the inside end of the tie rod wear out?
Users browsing this forum: No registered users and 229 guests
