How do you adjust camber
luke__
Postby luke__ » Fri May 04, 2012 1:24 am
I was trying to adjust the rear camber at work but i couldn't find it. I recently put in coilovers so it needs it done. I got the toe in/out all to spec just not camber :frown: . Can anyone tell me what to adjust or what it looks like that i should me adjusting. I need the front done aswell as the rear camber.
noddi85
Re: How do you adjust camber
Postby noddi85 » Fri May 04, 2012 2:25 am
Are you trying to get more or less camber?
You can buy more offset bushes to allow for more adjustment in the lower arms when you get a steering alignment, or you can buy adjustable top arms to help you even more.
I have adjustable top arms in gtr front and back. Mind you these are aftermarket arms.
Sometimes I wonder why i have different taste to others??? Then I realise its because Im not a sheep
PaulF
Postby PaulF » Fri May 04, 2012 3:02 am
This page should give you all the info you need, and then some. The images about 2/3rds of the way down have instructions for camber adjustment.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri May 04, 2012 11:35 am
unless you know what you are doing i would just get a proper wheel alignment done.
luke__
Postby luke__ » Fri May 04, 2012 7:44 pm
I've been working at Beaurepairs for 2 months, so i can do it properly. I'm pretty sure i was adjusting the right thing. One of the two bolts on the rear wishbone is the toe adjust and i'm pretty sure the other is camber it just wasn't doing anything. Moved the bolt 180deg and it did nothing. Maybe my car was in a accident or something idk lol. I asked the other guy at work and he was confused too. I flicked through http://www.miata.net/garage/alignment/index.html at work on my phone but i didn't have time to do it and it wasn't showing all the page anyway :( I'll try again tomorrow if i get time.
Postby NitroDann » Fri May 04, 2012 8:06 pm
luke__ wrote:How do you adjust camber
luke__ wrote:I've been working at Beaurepairs for 2 months, so i can do it properly. I'm pretty sure...
Jace
Postby Jace » Fri May 04, 2012 8:59 pm
haha good thread. if you can't tell by looking at it then you definitely shouldn't be allowed near anyone elses car!
i also appreciate that you're basically warning people not to take their cars to beaurepairs... cheers for that.
ak_perth
Postby ak_perth » Fri May 04, 2012 9:49 pm
Jace wrote:i also appreciate that you're basically warning people not to take their cars to beaurepairs... cheers for that.
lol, that's exactly what i thought when i read this thread! :oops:
project.r.racing
Postby project.r.racing » Fri May 04, 2012 10:51 pm
That is scary to think that you can adjust the camber after the toe and keep the toe settings. They haven't taught you how to do a wheel alignment yet have they? Do you do the front desk or the admin?
Please let us know which beaurepair you work at so we know not to go there. If your boss was reading this, well...
Guran
Vehicle: ND - 1.5
Postby Guran » Sat May 05, 2012 7:38 am
:lol: I'm now anxiously awaiting the thread "How do you weld an exhaust?"
Apu
Postby Apu » Sat May 05, 2012 7:41 am
Cue guy who welded nanotech's exhaust...
luke__
Postby luke__ » Sat May 05, 2012 1:53 pm
Completely taken out of context. I ment i can do it properly with cameras, not the string and level way in the link. My beaurepairs is pretty sh*t too lol i recommend not coming to it.
Jace
Postby Jace » Sat May 05, 2012 4:28 pm
it's basically been said and shown to you, but both LCA mounting bolts are known as "camber bolts" and adjusting them will give you camber and toe.
adjust one side more than the other and you will get toe in/out and a change in camber also, so you use adjust both bolts to get the toe setting you want and also however much camber you want.
tobias
Postby tobias » Sun May 06, 2012 11:24 pm
I can sell you some camber, how much do you need?
luke__
Postby luke__ » Tue Jun 26, 2012 7:48 pm
Bumping this cause i tried again, found out my camber washer was mangled. I took a pic of it but i gotta try find the cord to plug it into the computer. (I don't have and iPhone :roll: ). I'll probably go to Mazda on Monday to see how much they are, or where else can i get replacement ones? Most likely change my bushes aswell. Any specific ones you guys recommend?
Users browsing this forum: No registered users and 33 guests
