Andrew
Don't forget that Ford shares many components (Capri, Laser, Telstar etc)
project.r.racing wrote:A BA 94-98 mazda 323 astina (1.8, not 1.6) share the same rear rotor and pad with a na8/nb8, so assume the caliper is the same. I will add a side note to this that the 2.0 V6 version has the same rear rotors+pads, but the rotors are 5x114.3 stud pattern and the hub size is 67mm.
A BG 90-94 (1.8 DOHC, not 1.8 SOHC/not 1.6) share the same with NA6 from memory, but I really haven't delt with BGs or NA6s to confirm.
BG = KF/KH Laser
BA = KJ/KL Laser
