Mazdaspeed ride height adjustment
Posted: Thu Apr 26, 2012 3:50 pm
by Gladiator
My Na6 has mazdaspeed coilovers (see pic), but the drivers side is 25mm lower than the passenger side. My front right tyre scrapes on a hard left hander. Does any one know if the ride height is adjustable on these, and how easy to do for a fairly capable DIYer?
Andrew
Re: Mazdaspeed ride height adjustment
Posted: Thu Apr 26, 2012 3:56 pm
by hks_kansei
Those are not height adjustable ones. (Height adjustables were blue and silver, and had a great big threaded collar at the base)
However, from the pic you have the matching Mazdaspeed Springs, which lower the car by about 25-30mm from factory.
make sure all the springs are the same (did a previous owner maybe get confused and put the lowered springs on one side and forget the other?)
Other than that, they should be about the same height all around.
Posted: Thu Apr 26, 2012 9:22 pm
by Jace
remove overweight passenger?
Posted: Sun Apr 29, 2012 2:50 pm
by 93_Clubman
Gladiator wrote:My Na6 has mazdaspeed coilovers, but the drivers side is 25mm lower than the passenger side.
About 10mm lower on driver side is not uncommon, although tends to be the rear:
viewtopic.php?f=30&t=36867viewtopic.php?f=30&t=45747
