I've read on this forum that the offset of the NC's wheel is 55. Both Mullins and Speedy Wheels offer alternative wheel options for the NC with offsets of either 45 or 40. Given that Mazda selected an offset of 55 is there a disadvantage in using wheels with an offset of 45 or 40?
With thanks from slowpoke
NC wheel offsets
- Vehicle: 10AE
- Jeo
Re: NC wheel offsets
Offset varies with width. Are the new wheels the same width too?
- Regie
- Vehicle: NC - V8
45 is prolly the max offset you can run without rolling the guards.
Im running +45 on my NC as are a fair few other guys on here, no troubles at all...sits flush with the guard and look sweeet!
- Vehicle: 10AE
Thanks for your replies Jeo and Regie. I'm wanting to change wheel size from 17x7 to 15 inch. The wheels in question are either a Speedy Wheel 15x6.5 ET 40 offset or an ET 38 offset. Or a Mullins 15x6 ET 45 offset.
- Vehicle: Non MX-5
I wouldn't go skinner.
Can you even fit 15s on a NC???
Note that going to a smaller wheel may be illegal depending on state rules.
- Charlie Brown
slowpoke wrote:Thanks for your replies Jeo and Regie. I'm wanting to change wheel size from 17x7 to 15 inch. The wheels in question are either a Speedy Wheel 15x6.5 ET 40 offset or an ET 38 offset. Or a Mullins 15x6 ET 45 offset.
15" rims won't fit. The smallest you can go is 16" to clear the brake caliper.
I'm sure that you're looking at NB rims not NC. Make sure the pitch is 5 x 114.2mm not 4 x 100mm.
- Vehicle: 10AE
Thanks all for your replies.
Users browsing this forum: No registered users and 100 guests
