Urgent request: idiotproof DIY install YSR front coilovers?
Bizi
Postby Bizi » Sun Mar 04, 2012 8:45 am
Hi, I'll find a DIY thread if it exists, but first just want a quick answer.
The idea is to get these in so that I can get the wheel alignment at Spinning Wheel next Saturday.
I bought Rhys' (RS5800) Yellowspeed front coilovers and am keen to put the car on jack stands and remove the factory bilstein shocks/springs and install these coilovers.
These should just fit in. I just want to know what to look out for, in case there are any tricks or things to look out for. Do I need to compress the coilover with some kind of tool before installing?
I will need to adjust them, so hoping someone with experience can PM or text me ad I will phone you. I'd have gone to Mania yesterday but was out at the other end of Sydney all morning.
Thanks
Ben
PS. Jorgan92's thread noted he used a spring compressor; is this for the OEM springs and if mine are already very low springs, is this needed? Thx.
david_syd_au
Re: Urgent request: idiotproof DIY install YSR front coilove
Postby david_syd_au » Sun Mar 04, 2012 9:30 am
Even if you don't need a spring compressor to get the YSRs on, I think you will need it to get the original springs off.
I watched David at MX5 Mania install the YSRs in my NC around a year ago, and although I don't recall all the details I don't remember seeing anything that looked tricky.
Mr nanotech
Postby Mr nanotech » Sun Mar 04, 2012 9:49 am
If you are using spring compressors, you arw doing it wrong. Google 'long bolt' method. Basically just want to undo the sway bar, two bolts holding the shocker at to top of the tower and the long bolt on the lca. Everything should pretty much drop out. Oh and of course the bolt holding the bottom of the socker. Should be a straight swap then back together. Just crawling into bed after nightshift, so prob missed a couple of steps, but you should be able to work it out. Keep in mind the long bolt may be veeeeery tight, so dont hesitate to use the force. Id say goodluck but honestly, you dont need it.
egads
Postby egads » Sun Mar 04, 2012 9:51 am
Shouldn't need spring compressors for the Bilsteins. Just undo the sway bar bolts and the long bolt that holds one of the arms. Takes longer but gives you more clearance.
'90 red eunos na6
"the saddle club" - rider and horse are one
Mr nanotech
Postby Mr nanotech » Sun Mar 04, 2012 10:09 am
Longer? This is faster
spikes
Postby spikes » Sun Mar 04, 2012 10:14 am
It's quite straightforward, all you do is unbolt the original, swing it out and slip in the coilover, no tricks, no spring compressors since you are not taking the Bilsteins apart
jorgan92
Postby jorgan92 » Sun Mar 04, 2012 10:15 am
As other stated fairly straight forward, I needed spring compressors, I can guarantee that without them I couldn't have done it, but if the Bilstien's are shorter Maybe you wont need em.
Watch this for idiot proofness:
Part 1:
http://www.youtube.com/watch?v=3yryChmQd7o
Part 2:
http://www.youtube.com/watch?v=x572E1jl22M
I think he had Bilstiens and needed spring compresses... But I wont comment as I dont know the difference between the two size wise.
egads
Postby egads » Sun Mar 04, 2012 10:36 am
nanotech wrote:Longer? This is faster
Not unless you have a stubborn long bolt ;)
'90 red eunos na6
Postby NitroDann » Sun Mar 04, 2012 11:08 am
Nah, just use a hammer. Or undo the top bolt and the brake caliper (total of 3 bolts with very easy access) and pivot the arm down.
Kikuchi
Postby Kikuchi » Sun Mar 04, 2012 4:34 pm
if he's swapping shocks and springs for a set of coilovers (not just the springs) the long bolt method is the easiest as per previous posts.
if he's swapping springs you may need the spring compressors.
Apu
Postby Apu » Sun Mar 04, 2012 4:40 pm
I've passed my book to Ben, but have also suggested front only coilovers are not necessarily a good idea.
Postby Regie » Sun Mar 04, 2012 10:18 pm
Apu wrote:I've passed my book to Ben, but have also suggested front only coilovers are not necessarily a good idea.
Yep long bolt method I used on my nb when installing coils
I would recomend getting a rear set of coils too haha :D see you next weekend mate
Users browsing this forum: No registered users and 262 guests
