NB Sway Bar Link Bolts - Tighten When Wheels Are Off Ground?
Posted: Tue Feb 14, 2012 11:14 pm
Righto,
I'm making a few changes to my NB suspension and just need to confirm a few things if possible. I remember on my NA you had to tighten the sway bar end links with the wheels on the ground (or ramps) as the rubbers in the end links could tear otherwise when lowered from a car lift. I read somewhere that this doesn't apply to the NB model - i.e you can tighten the sway bars links with the car in the air on a lift?
Also - anyone know the torque to tighten the nuts on the end links to?
I'm also installing a set of coilovers - anyone have an idea what NB struts are torqued to when torquing the nuts?
Cheers in advance
Cheers in advance
