Uneven pad wear
mx5gem
Uneven pad wear
Postby mx5gem » Thu Feb 02, 2012 11:16 am
I've noticed lately that my rear brakes are only using half the pad area (the outer half further away from the centre)
(Std rotors, std pads, NB8A. )
I initially assumed it would be slider pins needing greasing, though now think this would only cause different wear rates for the inner and outer pads, not uneven wear on the same pad?
I dont have a picture of the wear so have stolen Beavis's pic from another thread to illustrate, (apologies for the theft..)
Essentially I am only wearing the red area, even though the pad covers the red & blue areas..
Anyone have any ideas what could be causing it?
floda
Re: Uneven pad wear
Postby floda » Thu Feb 02, 2012 11:34 am
I had the exact same issue - when investigated it was ungreased and bent slider pins. If it is left rear as mine was it may be the same problem. I have sme pictures I thinkn if you would like to see them PM me an email alias.
mx5gem
Re: Uneven pad wear
Postby mx5gem » Thu Feb 02, 2012 11:43 am
Cool. Mine is right rear but that's not really relevant as could still be same cause
Surprised this could cause that as the slider pins orientation to the pads is north-south whereas the wear is east-west.
oh. well. Real world result speaks for itself.
Thanks floda
floda
Re: Uneven pad wear
Postby floda » Thu Feb 02, 2012 11:59 am
It is strange and itwasnt until we pressed the caliper apart that we worked out the pin was bent. The dry pin could I supposed allfor some of the odd wear pattern as well.
Good luck with it.
Re: Uneven pad wear
Postby hks_kansei » Thu Feb 02, 2012 5:33 pm
If anything, re-lubing or replacing the slider pins won't hurt.
Users browsing this forum: Bing [Bot] and 3 guests
