rear caliper adjustment teeth stripped
koop21
Postby koop21 » Wed Jan 25, 2012 12:41 pm
Hey guys,
I recently bought a used na6 rear caliper but when i went to turn the adjuster nut it feel out and the teeth were stripped. Would replacing the adjuster nut be as simple as dropping it back in with a new one and hoping the internal is fine?
timk
Re: rear caliper adjustment teeth stripped
Postby timk » Wed Jan 25, 2012 1:09 pm
Hopefully that's the case. It is definitely worth a shot anyway!
Locutus
Postby Locutus » Wed Jan 25, 2012 2:00 pm
i'm told that you can buy the nut as a separate part from mazda.
the alignment nuts/bolts in early models tend to work their way loose, so were altered slightly from NB onwards. if you are planning to keep the car for a while, it may be worth doing the lot as most of them would be rusty and not doing a great job. if you do the lot, it's MUCH cheaper if you purchase genuine parts from the US.
koop21
Postby koop21 » Wed Jan 25, 2012 2:40 pm
the reason i bought a 2nd hand caliper because it was cheap and my one leaks around the adjust gear/ handbrake part. Anyways just visited mazda parts centre they didnt have the adjustment gear instock, but a thought came to mind. If i take out my adjustment gear on my caliper and use it in the 2nd hand caliper i just bought would this work also? If so how do i remove the adjustment gear? does it just simply fall?
Locutus
Postby Locutus » Wed Jan 25, 2012 7:57 pm
sorry - disregard my last post.
i must have been half asleep at work when i typed that... i thought u were talking about your alignment bolts. :oops: :roll:
mitch_f1
Postby mitch_f1 » Wed Jan 25, 2012 9:01 pm
Oh hey:
viewtopic.php?f=44&t=48116
You could also have a look down the adjuster hole and see if the teeth of the adjuster are stripped. It should be pretty easy to see if they are.
koop21
Postby koop21 » Wed Jan 25, 2012 10:10 pm
yeap was planning to do that; but apparently if the adjuster gear is wet with brake fluid the o-ring is gone. So im just gonna go purchase another caliper.
http://www.miata.net/garage/ebrake/index.html failure modes 2)
mitch_f1
Postby mitch_f1 » Wed Jan 25, 2012 10:36 pm
Yeh if it is wet or corroded you have issues.
