Tyre suggestion
- CoachOz
Tyre suggestion
I'm wanting to put 205/55/15 tyres on my car and don't want to break the bank. Short list so far:
Bridgestone Supercat $157
Federal 535 $175
Kumho KH18 $125
Toyo TEO $180
Any other suggestions?
Federal 535 $175
Kumho KH18 $125
Toyo TEO $180
- Charlie Brown
Re: Tyre suggestion
CoachOz wrote:Any other suggestions?
Yep, unless you have bought 15" rims for those rough roads, your NB8B has 16" rims.
Do a forum search as tyres have been discussed in full elsewhere here, though maybe not for ride.
Did you check your shocks?
PS. Sorry to tell you there has never been a 2000 "Special Edition" MX-5. Going on your photo you have a stock NB8B with aftermarket leather and door inserts. Not being smart just telling you so you know.
- Vehicle: Non MX-5
Re: Tyre suggestion
Or you could fit 205/50R15s and save alot of coin. 205/55R15s a rare and hence cost a mint.
- CoachOz
Re: Tyre suggestion
Thanks but I'm trying to maximise the rubber between the rim and the road to improve the ride on our lousy local roads. The other alternative is 195/55/15
- 16bit
Re: Tyre suggestion
195 55 15 are going to have a similar height side wall to a 205 50 15.
the 50 bit is a ratio to the width of the tyre.
look at the rolling diameter of the tyre and you will see what I mean.
a 225 50 15 is going to be about 20 or so mm taller 205 50 15.
- 16bit
Re: Tyre suggestion
195 55 15 is going to be about 10mm taller than 205 50 15.
205 50 15 will be about the same taller than 195 50 15
- CoachOz
Re: Tyre suggestion
I'm aware of that - more cushioning and slightly higher gearing - thanks
Re: Tyre suggestion
I hooked my car up with 4 x Toyo TEO Plus and I am very happy with them, heard good things about them too. But I note that they are the most expensive tyre on your list.
- Old Dude
Re: Tyre suggestion
I'm after tyres for the family car at present and Pirelli are doing good deals on the P7 at present, I have been quoted $174 for 225/60x17 so it might be worth asking the question.
Dale
Dale
MX 5 2001 Grace Green
NB8B
NB8B
Re: Tyre suggestion
I also put Teo plus on my Magna after a recommendation from my son.
Very happy though I'd have doubts about their suitability for an MX5
Rob
Re: Tyre suggestion
Sailor, how come?
Re: Tyre suggestion
I just have the feeling that they need a little weight over them to deliver.
Not unusual for a tyre to suit one size car better than others.
Just a feeling that's all...I'd probably be looking at a higher performance tyre on a 5 that's all.
Rob
- Entice
Re: Tyre suggestion
Personally, I am not a fan of teh TEO plus. Had them on a forester.. Granted, they were better than the Bridgestone D684's, but were not a confidence inspiring tyre for handling.
I think once you drive the car as it is intended, you'll want a more performance based tyre.. otherwise I feel it'll be quite tail happy and fidgety with mid corner changes...
but, that's just my opinion.
More opportunities have been lost from indecision, rather than wrong decision.
- Vehicle: Non MX-5
Re: Tyre suggestion
Just to put it out there also. Tyres only really account for 10-15% of your comfort. The suspension is where most of your comfort will be found. But you wanna sacrifice handling for comfort?
Re: Tyre suggestion
project.r.racing wrote:Just to put it out there also. Tyres only really account for 10-15% of your comfort. The suspension is where most of your comfort will be found. But you wanna sacrifice handling for comfort?
Unless you've got an NA6.
