Wheel offset
CoachOz
Wheel offset
Postby CoachOz » Tue Dec 06, 2011 7:07 am
How do I determine the offset on a set of aftermarket wheels?
2020 ND 2 GT
2000 NB Heritage
[imgImageHeritage 2 by Peter Rodgers, on Flickr[/img]
Old Dude
Re: Wheel offset
Postby Old Dude » Tue Dec 06, 2011 8:44 am
It should be stamped or moulded on the inside of the rim somewhere, its normally has et45 or something like that. Or you could measure it.
Dale 8)
MX 5 2001 Grace Green
NB8B
CoachOz
Re: Wheel offset
Postby CoachOz » Tue Dec 06, 2011 9:13 am
Thanks Dale
Sorry for my ignorance but what exactly do I measure?
2020 ND 2 GT
2000 NB Heritage
Old Dude
Re: Wheel offset
Postby Old Dude » Tue Dec 06, 2011 9:38 am
No problem, If you have say a 7" rim the centre will be 3.5" now the distance between the centre of the rim and where the actual inside of the mounting plate, is the offset.
This calculator might explain it better, just play around with the offset and you'll see what I mean. The offset is the column ET, I think its the last one up top on each wheel.
http://www.rimsntires.com/specs.jsp
Dale 8)
NB8B
CoachOz
Re: Wheel offset
Postby CoachOz » Tue Dec 06, 2011 9:45 am
thanks Dale
2020 ND 2 GT
2000 NB Heritage
