Chassis Bracing (underbody sub-frame) from MX5 Mania
Re: Chassis Bracing (underbody sub-frame) from MX5 Mania
Postby 93_Clubman » Tue Dec 06, 2011 12:10 pm
tommop wrote:I think with strut bracing the cornering will feel even more like a go-kart.
You won't notice a big difference with the addition of a brace across the front suspension tower. Some difference is noticeable, just not much. Good to hear the braces you've fitted so far are working so well.
jorgan92
Postby jorgan92 » Tue Dec 06, 2011 12:32 pm
Are these the ones that come standard on the NA8's?
Just the listing stops at like '93 or something?
Postby 93_Clubman » Tue Dec 06, 2011 1:05 pm
tommop wrote:i believe the na8's also had a seatbelt brace but i read someone that they were more for side impact procection than chassis rigidity (may be wrong).
Yeah, NA8 had the seatbelt tower brace, & it's a worthwhile addition to an NA6, unless you're going to add a rollbar at some stage.
