Just wanted to know what people set theirs at.
A) What suspension do you have?
B) What is your damper setting at, out of?
C) Do you change it depending on what you're doing?
D) What else do you have that would play a part on why you set yours where you do?
I know this is very general but i'm just curious.
A) BC BR coilovers.
B) Front: 18 from hard, out of 30.
Rear: 24 from hard, out of 30.
C) Not really, its my daily, I would if i didn't have to always take out the spare.
D) The roll bar made a massive difference, aswell as being quite low so when I have it too hard the smallest bump caused the back end to jump up and slide out if I was taking the corner hard.
Your damper setting?
I like my girls how I like my cars, topless.
- NitroDann
Re: Your damper setting?
the_darkside wrote:Just wanted to know what people set theirs at.
HKS Hippermax 3 Circuits
B) What is your damper setting at, out of? Right now, 6 from hardest front, 8 frpm hardest rear, 32 settings.
C) Do you change it depending on what you're doing? Absolutely.
Well under 900kg, adjustable whiteline swaybars, 90 duro rating race bushes etc
A) BC BR coilovers.
B) Front: 18 from hard, out of 30. These settings are not even close to transferable.
D) The roll bar made a massive difference, aswell as being quite low so when I have it too hard the smallest bump caused the back end to jump up and slide out if I was taking the corner hard. This is because you are on the bumpstops.
Thanks for the advice, but I wasn't on the bump stops, my wheel scrapes the guard first, which is why I had it set where it was, and I'm mainly asking out of curiosity, so thanks for you're reply
- Charlie Brown
Very general because of all the different shocks out there and the multitude of settings depending on spring rates and pre load but here goes:
An NC with Tein Flex 5kg front, 4kg rear.
15mm preload front and 10mm rear.
FatCat bumpstops.
16 position settings. Front 5 from full soft, rear 3 from full soft on the road. Just enough to control bounce. Track setting are a secret but hard, depending on track, tyre pressure, temperature and my driving on the day.
Biggest mistake I made: Not putting enough preload in originally and riding on the bumpstops (original Tein's) too much. In other words, too much droop.
Biggest improvement: preload and FatCat's.
- NitroDann
Lol 16 damper settings bit they are secret still, 1 in 16 chance of just guessing it:P
- Tedsmx5
- Vehicle: NA8 - Supercharged
NitroDann wrote:Lol 16 damper settings bit they are secret still, 1 in 16 chance of just guessing it:P
Dann's not sure himself as he can only count up to 6
My AGX KYB are set to 4 they adjust from 1 to 8.
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
- NitroDann
I dont get it...
My NB has tien flex 7kg front 6 rear set to teins recommended setting, racing beat tubular front and solid rear, torsen II, because a stiffer rear sway makes the NB pretty taily I tend to have the rear set pretty soft compared to the front
Oh, i'm in an NA and its 6kg rear, 8kg front.
- MINX
Many variables in this, but I will put my 2c in for the record.
SE with few stiffening mods, MX5 + Bar etc.
Racing Beat 1.125 Front bar, std SE rear bar.
BC Racing Coilovers 8/6kg
DD duties, and if I pass it to Lisa to drive, 15/15 (from 30)
My DD and round town duties, and evn club twisty mountain runs 12/12(from 30)
Swap on the Hankook RS-3s and off to Lakeside
Full Hard/Full Hard
Qld Raceway, maybe 6/6 from hard.
Full Hard/Full Hard
