install power steering help
cojack
Postby cojack » Thu Oct 27, 2011 11:50 pm
Hi guys need some Pics on how to mount the power steering return pipe (the aluminium one) that's kinks easily. its for a na6 with air con. need to know where to run this, eg between the radiator hose and return pipe or through the sway bar mount. some Pics from under your car will help heaps. been at it for 2 hours already
Re: install power steering help
Postby 93_Clubman » Fri Oct 28, 2011 11:22 am
No PS here, but this PS retrofit how to might help: http://www.miata.net/garage/ps.html
Matty
Postby Matty » Fri Oct 28, 2011 12:26 pm
93_Clubman wrote:No PS here, but this PS retrofit how to might help: http://www.miata.net/garage/ps.html
I wrote that and yes it is a tight squeeze.
