What brakes should I get
olboy
Postby olboy » Wed Oct 05, 2011 9:28 pm
Hi
I have a an unregistered NA6 that I use for track days and hillclimbs
I have just fitted a turbo setup and a torsen
I have done the suspension suspension and braces etc
Now I'm up to the brakes but I'm running out of money fast
I liked the look of wilwoods but with the dollar the way it is they are getting dearer by the day
Can anyone recomend anything else
PS I have 15 inch rims
Boyracer
MX-5 Encyclopedia
Re: What brakes should I get
Postby Boyracer » Thu Oct 06, 2011 8:42 am
I have a set of NB8B brakes for sale in Sydney.
olboy
Postby olboy » Thu Oct 06, 2011 11:05 am
PM sent
Postby 93_Clubman » Thu Oct 06, 2011 11:26 am
olboy wrote:PS I have 15 inch rims
Not all 15" rims will fit NB8B=>
But NB8A 15" rims will.
Postby Regie » Thu Oct 06, 2011 3:54 pm
have a look at the yellowspeed brake kits from mania
olboy
Postby olboy » Thu Oct 06, 2011 8:05 pm
I'm sure the yellowspeed are very good but the wilwoods cost alot less
I would like to keep it under $800
Boyracer has some NB8Bs for $800 but they are second hand and will probably need pads
Wilwoods are going to cost a little over $900 brand new with pads but thats only the fronts
I'm leaning towards the wilwoods
olboy
plohl
Postby plohl » Thu Oct 06, 2011 9:42 pm
spend less on brake upgrade, more on good pads
:beer:
plohl
olboy
Postby olboy » Fri Oct 07, 2011 6:34 am
So whats better bang for buck
nb8a front and rear $450 + pads $500 = $950
nb8b Front and rear $800 + pads $500 = $1300
Wilwoods $820 + prop valve $70 + Rear upgrade ?( i already have very good pads with std brakes ) = $890 + maybe upgrade
looking forward to any replies
olboy
hamx5ter
Postby hamx5ter » Fri Oct 07, 2011 7:30 am
olboy wrote:So whats better bang for buck
olboy
Best bang for your buck... nb8b f&R...
If you are spending money to upgrade brakes, I wouldn't waste it on upgrading to nb8a, go with nb8b or the willwoods. The nb8bs are still single-piston calipers vs. the willwoods 4 pots though, something to consider.
MINX
Postby MINX » Fri Oct 07, 2011 8:57 am
Open to offers on my SE Front brakes
http://mx5cartalk.com/forum/viewtopic.php?f=44&t=48893
Havent tested the Wilwoods on circuit yet(only Hill Climb) but on road- they are good, but i suspect a pad upgrade may have felt just as good.
The SE brakes are a good thing for most drivers, particularly with more aggressive pads for track work.
Wilwoods look nice :D
olboy
Postby olboy » Sun Oct 09, 2011 3:14 pm
Anyone know where to buy wilwood stuff in Australia
Olboy
olboy
Postby olboy » Sun Oct 09, 2011 7:38 pm
What your setup and how do you like it
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Oct 10, 2011 2:40 pm
Apu
Postby Apu » Tue Oct 11, 2011 3:39 pm
Sorry for the hijack but NB8B/C brakes are the same as the SE brakes, correct?
PeterB
Postby PeterB » Tue Oct 11, 2011 7:05 pm
On Fanta (ex Brian Anderson NA6 lightweight race car I used for supersprints - Wakefield 1.09.25 with n/a 1600) I used
Front NB8A front diameter slotted rotors with Willwood calipers and Willwood A compound pads
Rear NA6 front diameter slotted rotors with Outlaw calipers (similar to Willwood) and Willwood Q compound pads
No handbrake
No brake booster, Mazda master cylinder
Willwood bias adjuster in cabin
15x8" rims
I found this a very effective setup and the Willwood calipers are very easy to change pads on using the locating pins (easier than Mazda calipers).
Peter B
MX5 free for present
