Clicking/Rattling noise when going over bumps
itrungs
Postby itrungs » Thu Sep 22, 2011 1:44 pm
Hey,
So whenever I drive over bumps or potholes in the road, the car makes this clicking/rattling noise (near the rear wheels)
I took it to Midas for them to check out the exhuast and they said there was nothing wrong with it.
I took out the spare and the jack which did help but the car still makes the rattling/clicking noise regardless (its just not as loud as before).
Any thoughts? Help would be much appreciated.
Thanks
Caffeine
Re: Clicking/Rattling noise when going over bumps
Postby Caffeine » Thu Sep 22, 2011 3:44 pm
I'd suspect that the metal clips that stop the rear brake pads from rattling are worn out.
Put the handbrake on (slightly) and drive over a bump. Does it go away?
dazzana8
Postby dazzana8 » Thu Sep 22, 2011 7:38 pm
get a big breaker bar and make sure all suspension bolts are tight, while your there take a look around for any worn bushes that mite need to be replaced ...
BadBong
Postby BadBong » Thu Sep 22, 2011 7:41 pm
Agree with both comments above.
If you have a NB8B then the clips on the brake pads can sound like how you've described.
Otherwise, I've had an experience with loosing one of the bushes of my rear sway bar and that could make the annoying noise as well.
Caffeine
Postby Caffeine » Thu Sep 22, 2011 8:05 pm
dazzana8 wrote:get a big breaker bar and make sure all suspension bolts are tight, while your there take a look around for any worn bushes that mite need to be replaced ...
Just be careful you don't over tighten them, I had to replace one of my wishbones after I stripped the captive nut
itrungs
Postby itrungs » Thu Sep 22, 2011 11:54 pm
Thanks guys for the comments.
I'll try these things on the weekend, I have an NA6 btw, but these fixes should be common with all the 5's.
Results will be posted up on the weekend.
itrungs
Postby itrungs » Fri Sep 23, 2011 6:06 pm
Hey guys,
I read on miata.net that it could be some dirt & rocks stuck behind the brake shields.
So i took out my hose and sprayed water into the brake shield, around and around
And the sound disappeared. So basically it was just some rocks bouncing around everytime i drove. Such an easy fix.
Thanks for the comments though.
Users browsing this forum: No registered users and 248 guests
