Hi,
My NC has a bit of unstable steering and I was recommended to check the wheel alignment.
Could anyone suggest a good place in Brisbane to do the alignment for MX5?
What should be the toe-in and/or castor suggested for normal driving?
Thanks
Suggested Place for Wheel Alignment - NC MY06
- Learner Driver
- Charlie Brown
Re: Suggested Place for Wheel Alignment - NC MY06
Stock NC Suspension use these figures:
Front
1 degree negative camber
6.5 degrees castor
2mm total toe in
Rear
1.5 degrees negative camber
3.0mm total toe in
Front
6.5 degrees castor
2mm total toe in
Rear
3.0mm total toe in
- JBT
Jeff Graham at Accurate Suspension Services http://accuratesuspension.com.au/. He has done several MX-5s, sets up race cars and races cars.
