Custom wheel adaptors
red devil
Postby red devil » Sun Aug 14, 2011 12:01 pm
If anyone is interested iv found a company that makes custom wheel adaptors, which allow you to choose size, a new bolt pattern etc
http://www.motorsport-tech.com/wheel_adapters.html
Thought I should share
Cheers eren
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
Steampunk
Re: Custom wheel adaptors
Postby Steampunk » Sun Aug 14, 2011 1:33 pm
These are everywhere. Same theory for/against wheel spacers.
Patrick Bramston
Postby Patrick Bramston » Fri Aug 19, 2011 7:21 am
I need to run 17's to fit over my AP 330 mm disks and would like to run 17x9's with 235/40/17 semi slicks and have thought about wheel adapters.. Is the only problem that they act like spacers. I am thinking of running 15x10 on the back with 250/585/15 slicks and using my current 215/45/17 slicks on the front. Seems a bit odd having 2 inch smaller wheels on the back but it gives me 35mm more tyre on the back as wheel spin out of corners is a big issue with 180rwkw and 700 torques. ...
ANY THOUGHTS ?? Patrick
project.r.racing
Postby project.r.racing » Fri Aug 19, 2011 9:35 am
plate style spacers and bolt on adaptors are 2 very different things.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Aug 19, 2011 9:52 am
just get special order work emotion 11r in your psd. easy as pie.
Postby NitroDann » Fri Aug 19, 2011 11:47 am
Some dont want to spend thousads on wheels when 6ULs are just as good and very cheap.
Im sure patrick is included.
Patrick Bramston
Postby Patrick Bramston » Fri Aug 19, 2011 5:01 pm
HELP PLEASE..Where is the best place to buy the work Emotion 11r. Japan/USA/other .They seem to have 17x9 in +17,+28 and +38 in PCD 4x100 .What offset will go with coilovers and rolled guards..I think the offet on 15x10 6ul's is +25..thanks Patrick
Postby NitroDann » Fri Aug 19, 2011 8:11 pm
Lol,
Ill shut up now..
Patrick Bramston
Postby Patrick Bramston » Fri Aug 19, 2011 8:24 pm
I only want 2 for the rear, much better to have 17's with 245/40's..come on Dan wher can I get them from?? Somewhere that doesn't charge $500 for freight..PB
deviant
Postby deviant » Fri Aug 19, 2011 11:40 pm
Cant you talk to someone like http://www.metalspinnersaust.com.au/met ... pgodEGtX8Q or maybe see who is doing Simmons wheels these days. For a very specialised application it is worth getting the right thing for the right job and getting a set made to suit...it will be safe and it will be money well spent as it will work!
project.r.racing
Postby project.r.racing » Sat Aug 20, 2011 8:51 am
deviant wrote:Cant you talk to someone like http://www.metalspinnersaust.com.au/met ... pgodEGtX8Q or maybe see who is doing Simmons wheels these days. For a very specialised application it is worth getting the right thing for the right job and getting a set made to suit...it will be safe and it will be money well spent as it will work!
wheel Warehouse in Brisbane brought most of Simmons old manufacturering gear. They still do custom sizing in 15s and 17s only.
Patrick Bramston
Postby Patrick Bramston » Sat Aug 20, 2011 5:38 pm
I am going to find out Monday about changing the rear hubs to 5x114.3. Then 17x9's are a time a dozen. Patrick
red devil
Postby red devil » Sun Aug 21, 2011 11:10 am
Nice let me know how Pat!
Im looking to upgrade my hubs as well as i want to run bigger bearings in the hubs so i can get the engineer to sign off on my new wheels
Cheers eren
