empty brake fluid reservoir
mitch_f1
Postby mitch_f1 » Wed Jul 13, 2011 9:04 pm
Hey,
So I did a silly thing while changing brake calipers, I let the reservoir empty (wasn't paying attention). Now, for bleeding there is going to be an exceptional amount of brake fluid in the lines (I also changed the brake lines, so even more so I guess). My question is I have brought 3 bottles of RBF600 (got a good deal), and I don't want to waste it. Should I begin bleeding with some cheaper fluid, or if I fill reservoir with RBF and then begin bleeding, by the time RBF gets to caliper there will be no air in that line?
Cheers for any help :)
emexv
Re: empty brake fluid reservoir
Postby emexv » Wed Jul 13, 2011 9:11 pm
I don't know what that stuff is worth but unless it's super exy I don't think I would bother. I think you would be better off bleeding all the old stuff out and ensure you only have one type left in there. If you add another cheap bottle you run the risk of having three different types of fluid in the system. Sort of defeats the purpose of using good quality fluid. One bottle should just about do it I would think. Definately wouldn't use more than two.
Mark
timk
Postby timk » Wed Jul 13, 2011 9:24 pm
You may as well use it up, it doesn't generally have a good shelf life.
When I fitted new brakes and lines I didn't use more than 2 bottles.
mitch_f1
Postby mitch_f1 » Wed Jul 13, 2011 11:17 pm
Reassuring to know, thanks :)
project.r.racing
Postby project.r.racing » Thu Jul 14, 2011 9:06 am
If you have let the tank empty out. Then there will be a air pocket between the 2 fluids anyway. You'll know when the fluids change eaily.
You'll only need 2 bottles. I did a complete flush of my system with RBF600 and still had 200ml left in the 2nd bottle. That was with roughly 30-40mm of the new stuff coming out when bleeding per corner.
See if you can get your money back for the 3rd bottle.
jerrah
Postby jerrah » Thu Jul 14, 2011 9:20 am
Or do the clutch?
I used three bottles to completely refill my empty brakes and flush the black stuff that was pretending to be DOT4 out of my clutch lines. Took forever to bleed the clutch...
1991 MX5
project.r.racing
Postby project.r.racing » Fri Jul 15, 2011 9:57 am
Oops yeah I did my clutch also.
