I seem to have a clicking noise from my front right calliper
My car is a NA 1.6 and they are off an NB8A
I have greased the sliding pins and it has lessened the noise slightly, any ideas?
Cheers Eren
Clicking brakes
Clicking brakes
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
- Charlie Brown
Re: Clicking brakes
red devil wrote:I seem to have a clicking noise from my front right calliper
Cheers Eren
Missing the spring steel location clips so the pad's just floating around in the caliper slot?
See here: http://www.mx5parts.co.uk/product_info. ... cts_id/954
- NitroDann
Re: Clicking brakes
Sounds right. Many lose the locating clips, not to be confused for the backing plates.
Without them, the friction is higher between the disk and the pad, than between the caliper and pad, and so the disk drags the pad around a couple mm until it whacks the caliper.
Its NOT a safety issue i might add, hopefully give you some relief.
Re: Clicking brakes
thats sounds like the problem!
Like Dann said it hasnt affected the braking performance any, but its just so farking annoying
I might be getting some new parts ie pad separating springs and clips! i dont have the pad backing plates though, might look into finding some today
Cheers eren
Cheers eren
- NitroDann
Re: Clicking brakes
ont buy the backing pads, they are a major cause of rattling and squeeling due to them vibrating.
Buy a tube of antisqueel. Its a rubbery glue that glues the pads to the caliper, stopping them from making any noise at all. Keep the locating clips but use this instead of backing plates.
- RawSouth
Re: Clicking brakes
Email Mazdatenfive and see if he has some clips, or if you buy the OEM pads from MX5parts.co.uk, they come with the clips included.
Josh
Josh
ロードスター
Re: Clicking brakes
Nice!
Dann is the blue or orange stuff? or will either do? Locutus has a new set of springs and clips for me, i'll try and grab them off him ASAP
eren
eren
Re: Clicking brakes
replaced all the clips, separating clips and geased the pins and its all good now cheers for all the imput!
Users browsing this forum: No registered users and 143 guests
