Mx5 nc rims question
Gmi
Postby Gmi » Fri Jul 01, 2011 5:23 pm
Do these fit under a nc mx5?
17 x 8 +51 fronts with Advan AD08 225/40
17 x 9 +63 rears with Advan AD08 255/40
Cheers guys.
NC2005
Re: Mx5 nc rims question
Postby NC2005 » Fri Jul 01, 2011 8:09 pm
Gmi wrote:Do these fit under a nc mx5?
Cheers guys.
Fronts no problem.
Rear , you going to be going out by 33mm (compared to standard 205's on 7"). Thats 8mm on the offset and 25mm each way on the tyres.
Sailor
Postby Sailor » Fri Jul 01, 2011 8:48 pm
Fronts will be OK, rears will almost certainly foul on the inside.
Rob
Gmi
Postby Gmi » Sat Jul 02, 2011 2:06 am
So the rear will scrape the inside!! Ok.. 20mm spacers atvthe rear and I'll be running go kart wheels ( tyres sticking out of the guard ) ???
Sailor
Postby Sailor » Sat Jul 02, 2011 10:04 am
Nope, +63 means that the mounting flange on the wheel is 63 mm toward the outside from the centre of the wheel.
Bigger the number, further IN the wheel sits.
Rob
NC2005
Postby NC2005 » Sat Jul 02, 2011 1:47 pm
Gmi wrote:So the rear will scrape the inside!! Ok.. 20mm spacers atvthe rear and I'll be running go kart wheels ( tyres sticking out of the guard ) ???
Go with 17 x 9 with +48 offset. 235 x 40 will fit fine. Any wider and you will probably have to roll the fender slightly.
Users browsing this forum: No registered users and 25 guests
