Just not sure what exact diameter it is!
Thanks for the help
What's the hub diameter for stock nc 17inch rim?
- NitroDann
Re: What's the hub diameter for stock nc 17inch rim?
English much?
Do you mean the pitch circle diameter?
Not the pcd. The hole in the rim.
Hey dann, I got the answer
Hub bore diameter 67.1mm
Can someone confirm that??
- Vehicle: Non MX-5
yup all mazdas with a pcd of 5x114.3mm have a centre hole of 67.1mm.
