Fat Cat Motorsport Shock Mounts and Bumpstops
Re: Fat Cat Motorsport Shock Mounts and Bumpstops
Postby 93_Clubman » Thu May 12, 2011 12:37 am
mxfarm wrote:Has anyone had experience with Fat Cat NA shock mounts and bumpstops for Koni Yellows with Kingsprings . Was thinking about 46mm bumpstops. Also has anyone ordered these from Fat Cat Motorsports in the US
Quite a few forumites have ordered from Fat Cat Motorsports.
zossy1
Postby zossy1 » Thu May 12, 2011 9:36 am
I had a set on my car when I was living in the US. They are great. The mounts though are very similar to the effect you would get by installing NB mounts. If you run NA springs you could lose some ride height (esp. in the rear).
xmx106
Postby xmx106 » Thu May 12, 2011 11:49 am
I purchased some 46mm bump stops and red boots for my 1990 NA a year ago. No problems dealing with them, they answer emails pretty quickly, they lost my shipping address at one point. I think that these bump stops are great and are just a better economic choice than going for a stock bump/boot replacement.
I am running them with KYB AGX adjustable shocks and standard height king springs. My shock mounts are standard, but I did toy around for a while thinking about the fat cat shock mounts or trying to pick up some NA series 2 shock mounts.
My AGX shocks are set to a soft position 3 front and 4 back (8 positions) all round for normal every day driving, it drives nicely.
The height on standard king springs is naturally stock and most forum members want to drop an inch or so but I have been lower on bilsteins and RS*R springs before and I had speed bump and a driveway kerb issue's. Behind the front wheels bottomed out and the underside of the rear bumper has gravel rash from running about 30mm lower.
1990 NA eunos roadster for me, 2007 NC roadster for the misses, missed out on the NB?
Matty
Postby Matty » Thu May 12, 2011 2:27 pm
By the way the fatcat bumpstops are the same items sold by Ground Control for less.
http://www.ground-control-store.com/pro ... .php/II=10
Fatcat cuts some of them to length though...
