Hi, I am on the edge of purchasing some excellent condition used jdm wheels
The wheels are 14 x 6.5 + 14 and 14 x 7 +10
I have a few questions, and yes I have used the search function its just hard to get specific answers.
Will the difference of half an inch make wheel alignment/driving issues I have only had equal sized wheels previously.
The centre caps are non existant would sourcing aftermarket caps for this be difficult-
Lastly would I be best to stick with a 205 tyre or go down to the 195 for a snug fitment.
All feedback positive or negative is welcomed many thanks
wheel size questions - advise requested
Re: wheel size questions - advise requested
the half inch won't make much (if any) difference, especially since I presume you'll use the same sized tyres front and back.
Centrecaps, depends on the wheel, some can fit any generic cap, others need a weird mount or size.
as for 205 vs 195, I'd personally go a 205, BUT you'll need to do some measuring to see that you arent going to have scrubbing issues with the low offsets. (not sure what sort of clearance the NA has for wheels)
- Jeo
How low is the car and what kind of profile are you thinking for the respective tyre choices?
I'm currently using 17inch aftermarket rims (came on car) on 205 Achilles semis which are in need of a change.
I'm rolling on stock suspension atm but I'm looking to invest in a decent set of road friendly coil overs, i intent to put some 205 tyres but im not after a low profile or semi slick compound and don't want the rubbing to become an issue.
Glad for the feedback thanks
- ak_perth
Personally i quite like the stretched/snug fit look for tyres.
There is a HUGE post below were people are discussing tyre fitment. Loads of info and photos for you to look through:
http://clubroadster.net/vb_forum/showthread.php?t=25080
AK
AK
