rear adjsutable uppers
lukearama
Postby lukearama » Fri Apr 29, 2011 9:08 pm
Apart from Mazda............ trust nothing else...
Si.G
Re: rear adjsutable uppers
Postby Si.G » Sat Apr 30, 2011 12:18 am
Not fitted them personally, but you can find stories of them breaking on other forums if the car is run really low because they hit on the chassis before the bump stops are reached. - http://forum.miata.net/vb/showthread.php?t=342639
These woudld be a better option - http://www.awrracing.com/blog/2009/05/14/new-camber-adjustable-rear-upper-control-arms-for-miata/
In any case you can usually get 2-3 deg of neg camber anyway if the car is lower than standard, I am not sure why you would need more
Si.
NA6 B6T
