NB8A: Bilstein Sport B8 damper with Standard factory spring
ckwan028
Postby ckwan028 » Thu Mar 31, 2011 7:20 pm
Hi All,
My first post: :D
They dont fit together. The dampers is too short for the spring.
I am looking at getting Tein S-Tech for my car now
Anyone had any experience with this combination?
and anyone know the standard spring rate?
The Tein is Front 6 Rear 4.5
Thanks in advance
Milky
jonosx
Re: NB8A: Bilstein Sport B8 damper with Standard factory spr
Postby jonosx » Fri Apr 01, 2011 8:45 am
Why do you feel they are too short for the spring?
The B8 range is designed for use with lowered springs but will also still work with standard springs.
The spring will just be compressed a little more when assembled but this wont really affect anything.
Postby hks_kansei » Fri Apr 01, 2011 8:51 am
also, the Tein S Tech is available in more than one rate.
there's soft, medium and hard (I don't think the NB version came in hard)
the rates there of 6 and 4 are for the medium from memory?
ckwan028
Postby ckwan028 » Fri Apr 01, 2011 9:20 am
Hi All,
The S-tech spring is medium
My mechanic took the rear shocks off and tried to fit them. The different in length is actually quite big.
Maybe he is afraid he may damage the shocks??
He really gave me a very good excuse to lower my car :D
Anyway. bought the S-Tech spring off ebay
fingers crossed
8)
Milky
zossy1
Postby zossy1 » Fri Apr 01, 2011 12:37 pm
Are you sure the shocks are the NB model?
If you have bought NA shocks the the NB rear springs in particular will be too long.
ckwan028
Postby ckwan028 » Fri Apr 01, 2011 3:38 pm
Hi zossy1,
The P/N I got is BE5-6550,BE5-6551
Thanks
Milky
jonosx
Postby jonosx » Fri Apr 01, 2011 3:49 pm
Thats the correct part number for the NB.
I work for Bilstein Australia and we have never had a problem fitting them here with standard springs, and havent had feedback from our customers or workshops indicating there is a problem.
Not sure why there has been an issue in your case.
zossy1
Postby zossy1 » Fri Apr 01, 2011 3:50 pm
ckwan028 wrote:Hi zossy1,
Thanks
Looks correct...
ckwan028
Postby ckwan028 » Fri Apr 01, 2011 4:23 pm
May I suggest my mechanic is too "chicken" to compress the standard spring too much to fit the spring "into" the shocks???
:lol:
hopefully my Tein S-Tech arrive and it will be a good fit..
I had experience with Bilstein shocks on my old vectra before and I love it...
:D
Milky
ckwan028
Postby ckwan028 » Wed Apr 06, 2011 7:21 pm
ok, Tein S-tech with bilstein installed..
Love the ride, actually abit too soft for my taste.
I actually need to look under the car to confirm they did indeed change the spring and shocks
Question: Should I do a 4 wheels alignment?
My mechanic told me not needed. Drive for a few days see how it goes.
Reason being they didn't touch those tie-rod or other suspension component.
But I think I may need it since the ride height is different now. I dont want the road to eat my rubber. you know. Tyres are expensive...
Milky
zossy1
Postby zossy1 » Thu Apr 07, 2011 9:59 am
ckwan028 wrote:ok, Tein S-tech with bilstein installed..
When you alter ride height, a full 4 wheel alignment is strongly recommended to allow for the change in geometry (especially camber) resulting from the lowering.
Postby hks_kansei » Thu Apr 07, 2011 10:05 am
as above.
technically you should get an alignment after anything suspension related is changed. In reality not so much (as in the difference is often 2/3 of ƒü¢k all)
depending of course on what's changed.
but yeah, certainly after lowering a car.
Give it a couple of weeks of normal driving for the springs to settle, then get an alignment.
if you get it straight up when the springs settle it might change it a little more.
ckwan028
Postby ckwan028 » Thu Apr 07, 2011 12:10 pm
Thanks all for ur advise
Milky
