Unless you are going to go a proper rally tyre (no idea about these, but I imagine expensive and fast wearing on anything that isn't dirt) your only other option for an off road tyre which typically come wide with a very tall aspect ratio (eg 265/75 R17) which is more than likely not going to fit under your guards ;)
Having taken both my Skyline (aftermarket 17" wheels) and Liberty (factory 18" wheels) bush on many occasions I don't see why one couldn't use a 17" with a "all round" style tread. If it really bothered me I'd consider a smaller wheel to allow a higher profile tyre to absorb whatever bumps there are on the road...
If you want to go fast on dirt... I think you should take a quick look at the kind of cars that enter WRC ;)
Off Road Tyres ???? R17's
- HIC-45S
Re: Off Road Tyres ???? R17's
スカイライン ECR33 GTS25-t SII
"We produced with Spartan air"
- Vehicle: Non MX-5
i'd go back to the smallest diameter wheels with regular tyres.
x2 for the smallest lightest tough wheels and tyres you can find. So 14 x 6 with 185/60R14 tyres if it's an NA. I'm doing the occasional bit of dirt in mine.
Going to much stiffer springs on my Teins (up from 5/4 to 10/7 Kgmm, where stock is around 3/1.5) has made it surprisingly better planted on dirt and corrugations.
