What cir-clip setting when using Koni + Kings
jerrah
Postby jerrah » Thu Feb 24, 2011 8:24 pm
When I bought my MX5 it was fitted with King lowering sport springs on Koni Yellows.
These were set to the lowest cir-clip setting. I was scraping on everything so I set it to the middle perch. This has been ok but I still find my car scraping the middle on driveways and speed humps. I've just signed a lease on a new flat and I've found no possible way to enter the garage without touching underneath.
My first thought is to go to the highest perch but I'm wondering if I should keep the perch at 'clubman' setting and use different springs? Constant rate springs rather than progressive seem to be the rave with coilovers - is there something similar for the Koni's?
What is everyone else using?
1991 MX5
rwf
Re: What cir-clip setting when using Koni + Kings
Postby rwf » Thu Feb 24, 2011 10:06 pm
check with king springs there might be a standed hight spring in there range or they custom make to fit
SOLD. MX-5 NA 2F RACE CAR -LAKESIDE 1:04.91 -QR Clubman 1:06.3608
SOLD. Mx-5 NC 2007
Mazda 3 sp25 2015
MX-5 NB
Locutus
Postby Locutus » Thu Feb 24, 2011 10:11 pm
try the rears on the highest perch before you try anything else. you will probably find that your ride quality will improve as well.
there isn't much sense in trying to match clubman ride height if you don't have clubman suspension - shock travel, bump & springs rates will be different to the clubman setup.
jerrah
Postby jerrah » Thu Feb 24, 2011 10:40 pm
Surely it should best be matched height front and rear?
I guess I'll try full height first and see how that clears the driveway and get a fresh wheel alignment. I hate spring compressors. :|
1991 MX5
Locutus
Postby Locutus » Thu Feb 24, 2011 10:51 pm
for best stability, the rear of the car should be slightly higher than the front. on my NA8, the rear was still pretty low on the highest setting.
if you're brave, it is possible to move the circlip without spring compressors:
viewtopic.php?t=30691
the pics no longer work, but basically you can use a big leaver and the half shafts as the fulcrum on each side.
Si.G
Postby Si.G » Sun Feb 27, 2011 8:06 am
Also, if you go to the lowest setting on the back with the stock top mounts you will be pretty much on the bump stops and this does not make for good handling - been there with the same setup on my NA6.
NA6 B6T
jerrah
Postby jerrah » Mon Feb 28, 2011 12:12 am
It's now at the highest setting. It drives ok but I should chase a wheel alignment asap.
1991 MX5
