brake servo vacuum hose
mitch_f1
Postby mitch_f1 » Wed Dec 22, 2010 10:59 pm
Just wondering how these are supposed to feel like; mine seems quite hard, with a harder bit in the middle? Could it be old and possibly leaking a bit.
I am searching for things that could be giving me a soft pedal feel.
Re: brake servo vacuum hose
Postby orx626 » Wed Dec 22, 2010 11:10 pm
Hi Mitch, that hard thing in the middle is a one-way valve (check valve). Whatever you do don't remove it or you will have virtually no brake booster assistance. With regards to the spongy pedal, did this just happen or over a period of time?
Steampunk
Postby Steampunk » Thu Dec 23, 2010 11:06 am
orx626 wrote:... don't remove it or you will have virtually no brake booster assistance...
Well... you can, but don't put it back in the wrong-way-round :mrgreen:
Short answer is 'yes' , the hose is very stiff in order to uphold the vacuum forces going through it.
Spongy pedal feel (under normal driving conditions) is symptomatic of old brake fluid, bubbles in the fluid, or failing brake lines.
mitch_f1
Postby mitch_f1 » Thu Dec 23, 2010 10:17 pm
orx626: ive had the car a little over a year so unsure
thanks 1red5. Everything else about the brakes is new except the rear lines. So they might be next on the list
Users browsing this forum: No registered users and 293 guests
