ABS?
Purfler
ABS?
Postby Purfler » Sat Sep 18, 2010 7:34 pm
Ok, long ago I realised that I'm as thick as the proverbial...
About two months ago I bought a '93 NA LE. One of the best things I've done for ages. It has a relay for ABS and the Wikipedia entry says LE's had ABS. However, that entry says a bunch of things about the LE which clearly do not apply in Oz - especially about colours. I decided to investigate, and clean the front suspension at the same time (as you do). Bargared if I can see ABS hubs. As they say in the classics, please explain?
Thanks,
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
RawSouth
Re: ABS?
Postby RawSouth » Sat Sep 18, 2010 7:36 pm
I thought that ABS was first introduced to Australian MX5s with the NB8B. (Oct 2000->)
ロードスター
Locutus
Re: ABS?
Postby Locutus » Sat Sep 18, 2010 7:46 pm
yep, only from NB8B in AU.
ABS was available in NA models in other markets though, so yes it's possible to retrofit. probably not an easy task though.
Caffeine
Re: ABS?
Postby Caffeine » Sat Sep 18, 2010 8:16 pm
Locutus wrote:yep, only from NB8B in AU.
And the 10AE...
Purfler
Re: ABS?
Postby Purfler » Sun Sep 19, 2010 8:37 am
Thanks for the replies. Don't suppose anyone knows what the ABS relay does then?
Regards,
Tim
Users browsing this forum: No registered users and 331 guests
