NA Front Upper Control Arm Ball Joint Replacement
mazdatenfive
Postby mazdatenfive » Wed Sep 22, 2010 8:19 pm
Wondering if any one knows how to replace ball joint on upper front NA control arm.
My research says you need to buy a replacement.
Any one know of a simpler fix.
mazdatenfive
Re: NA Front Upper Control Arm Ball Joint Replacement
Postby mazdatenfive » Thu Jul 28, 2011 11:25 am
Does anyone know anything thay may help.
CheyneX5
Postby CheyneX5 » Thu Jul 28, 2011 3:01 pm
I was told by my mechanic that it's much better to get a new control arm, it's an expensive task either way.
90' NA6 - Classic Red
de Bounce
Postby de Bounce » Thu Jul 28, 2011 3:11 pm
According to Mazda, the ball joint is part of the upper arm and is repaired/replace as part of the complete upper arm assembly.
Could try to source a good second hand one or new from Mazda or MX5 Parts UK
Good Luck
Motorkhana Video
mazdatenfive
Postby mazdatenfive » Thu Jul 28, 2011 3:15 pm
Dam there expensive! :roll:
de Bounce
Postby de Bounce » Thu Jul 28, 2011 3:28 pm
mazdatenfive wrote:Dam there expensive! :roll:
Cheaper than a NB with ABS :twisted:
Motorkhana Video
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Thu Jul 28, 2011 5:41 pm
What model do you need?? I have a few in the shed.
mazdatenfive
Postby mazdatenfive » Thu Jul 28, 2011 6:20 pm
Boyracer wrote:What model do you need?? I have a few in the shed.
NA6 or 8, think they are the same.
CHRISTolo
Postby CHRISTolo » Mon Jul 16, 2012 2:08 am
Just read this -http://www.carcare101.info/project-miata/v8-roadsters-rebuildable-upper-ball-joint-installation/
Removal is the hardest part, local pedders/brake mechanic may have a press.
Front upper ball joints are critical to accurate steering. Until now, the only way to get replacements for worn-out ball joints was to buy entire new control arms from Mazda for over $300 per pair. V-8 Roadsters has finally solved this dilemma with their replacement ball joints. They are far higher quality than the factory ones as well as being adjustable, rebuildable, and lubricate-able.
taper on ball joint fits all NA and NB front spindles
splines on housing match stock Mazda control arms for easy replacement
tension-adjustable
Zerk fittings for refilling with grease
copper-plated hardened steel studs
billet aluminum housing is hard anodized for protection from the elements
includes boots, castle nuts, cotter pins, and washers
Price for both sides $150 USD
http://www.miataroadster.com/v8_roadste ... 09013.aspx
Users browsing this forum: No registered users and 210 guests
