I have bought factory alloys for my 89 NA and am after a set of standard wheel nuts to suit
The alloys have a cap that covers the wheel nuts, my mag wheel nuts are too tall and too wide for the stud opening
I've tried a couple of wreckers, who might be able to rustle up a set, but don't sound overly confident of having a full set
Does anyone in Adelaide have a set to sell or can anyone recommend where I can get some cheap?
Wheel nuts
- broady
Re: Wheel nuts
Try Mazda if you havent already. Itd probably cost heaps though
人馬一体 NA8
6/5/2010
- Learner Driver
Re: Wheel nuts
Mazda quoted something like $7 each
Re: Wheel nuts
try Mania, Mx5Centre etc ?? They could post
Robbo
[strike]Laguna Blue NA6, NB Titanium SE, 1993 Red NA6, 1990 BRG NA6[/strike], Granpa Grey NC1
MX5 #5, an NC series 1 this time !
- Elmo
Re: Wheel nuts
Depending on how long you want to wait you can have my old set for $20.00
Re: Wheel nuts
Try a wrecker. The wheel nuts will fit a number of different Mazda models. I bought a full set from a 323 for about $25 from a wrecker a few years ago.
J
J
- Vehicle: 10AE
Re: Wheel nuts
they are about 12 x 1.5
should be able to get them at most motoring stores
I got mine $10.95 for 5 at MalZ(WA)
- Learner Driver
Re: Wheel nuts
Many thanks,
I found out that they are in fact 12 x 1.5 and that they are common to all Mazdas and are known as open wheel nuts
Bought a full set from Mazwreck for $16
Problem solved very cheaply
Thanks again for the advice
Paul
Paul
Re: Wheel nuts
Probably too late now, but make sure the nuts are for alloy wheels.
you arent supposed to use steel nuts on alloy wheels, or vice versa.
it's basically because steel is harder and can over time chew into the softer alloy.
