new coilovers, guard scrubbing
WhiteNA6
Postby WhiteNA6 » Tue Jul 20, 2010 7:08 pm
hey all.
just purchased a set of the BC BR coilovers and fitted them.
only problem is now pulling into my driveway with the dampening on 20 all round, i catch the front left guard with the tire just a little.
i assume its the same on the right side with likewise driveways.
it is only under load, and if i pump up the dampening to 30 its stiff enough to support the car and dosent scrub.
so my main question is does anyone know anybody who lips/rolls guards etc.
i would prefer not to drive around on 30 dampening for long so if so please pm me asap.
cheers guys.
chris
The Secret Weapon
olboy
Re: new coilovers, guard scrubbing
Postby olboy » Tue Jul 20, 2010 7:20 pm
Try winding the bottom cup down a bit ( raise the ride height )
WhiteNA6
Postby WhiteNA6 » Wed Jul 21, 2010 8:51 pm
yeah i was hoping to not have to do that since the height is perfect for looks at the moment.
might have to though if i cant find a better fix.
The Secret Weapon
broady
Postby broady » Thu Jul 22, 2010 12:50 am
yep mate
im either getting mine rolled by nelson @ sydney guard rolling or if i can be bothered going to ingleburn.... luis @ drift garage.
人馬一体 NA8
6/5/2010
WhiteNA6
Postby WhiteNA6 » Thu Jul 22, 2010 11:21 am
ill look into them,
cheers broads
The Secret Weapon
project.r.racing
Postby project.r.racing » Thu Jul 22, 2010 8:58 pm
if it ain't happening between 10 points of dampering force. then even raising it only 2mm should solce your problem. and keep the look that your require.
94 clubman perth
Postby 94 clubman perth » Thu Jul 22, 2010 11:45 pm
I agree, cant be much in it if altering the damping is restricting compression enough not to cause the problem-Im guessing you have some biggish offset rims? Whats your ride height (chasis rail to ground or center of wheels to under guards).
WhiteNA6
Postby WhiteNA6 » Sun Jul 25, 2010 12:50 am
front left - 290
front right - 290
rear left - 295
rear right - 295
that is center of wheel to guard.
wheels are 15x8 +25
ill pop it up 5 mm all round tomorrow and then lower the dampening and see how that ends up.
but ultimately whilst tracking i will want it as low as possible without scrub, so guard rolling will need to get done eventually im assuming.
The Secret Weapon
Charlie Brown
Postby Charlie Brown » Mon Jul 26, 2010 1:39 pm
WhiteNA6 wrote:.........but ultimately whilst tracking i will want it as low as possible without scrub........
No you don't :!:
The lower control arm should not pass the horizontal line when you lower the NA. There is plenty of information on this if you do a search.
Also remember to do an alignment after the height has been set.
Postby sliq » Mon Jul 26, 2010 2:29 pm
yup, what CB said. everytime you have your wheels aligned, they do it based on the height it currently sits at.
WhiteNA6
Postby WhiteNA6 » Mon Jul 26, 2010 5:08 pm
ahh i see.
ill take it down tomorow and get that done.
if there anything i need to know in short in reguards to ride height whilst tracking?
The Secret Weapon
Guran
Vehicle: ND - 1.5
Postby Guran » Mon Jul 26, 2010 5:20 pm
WhiteNA6 wrote:if there anything i need to know in short in reguards to ride height whilst tracking?
Yep. Lots of detail here:
http://www.specmiata.com/download/sm_setup_guide_v2.pdf
Users browsing this forum: No registered users and 341 guests
