Hi I am replacing the rear axle/hub bearings on my NA 1800,I have searched for torque settings for the 29mm nut with varying results
ie 159-217 ft lb's, which sounds like a lucky dip. Can anyone be more specific.
Steve
Rear Hub axle nut torque settings
Re: Rear Hub axle nut torque settings
According to Haynes & Rod's manuals: 160-216
- de Bounce
WASP wrote:Hi I am replacing the rear axle/hub bearings on my NA 1800,I have searched for torque settings for the 29mm nut with varying results ie 159-217 ft lb's, which sounds like a lucky dip. Can anyone be more specific.Steve
Aim for a ball park figure of 190 ft lb
When you get up to this size bolt, the tolerance on correct torque can be quite large.
Assume you are using new nuts!
Users browsing this forum: Google [Bot] and 353 guests
