Do I need Brakets to Fit NA8 Calipers
XB12R
Postby XB12R » Mon May 10, 2010 6:25 pm
Hi,
Not 100% sure or not if I need Brackets to fit NA8 calipers to my NA6 obviously will fit NA8 Rotors as well. If I do is it possible to get the specs as i could probably get them fabricated by my father.
Cheers!
89 NA6
Is always hard to chose between the 5 and the Ducati
Postby Jeo » Mon May 10, 2010 7:01 pm
No brackets or anything special required. All you have to do is swap the left and right side calipers. Very easy task, I knocked out mine in <30min.
Veloce
Postby Veloce » Wed May 12, 2010 5:59 pm
Pardon for butting in, is that for both front and back?
Make something idiot-proof, and somebody will make a better idiot.
2007 Limited Edition (back in the saddle again)
Postby Jeo » Wed May 12, 2010 9:27 pm
I think rears just bolt straight in but don't quote me on that, I didn't do the rears on mine.
XB12R
Postby XB12R » Thu May 13, 2010 6:14 pm
thanks for the reply, Yeah I was just going to do the fronts too. Hopefully saturday =D
89 NA6
