Will Evo 17x7.5 Rims with 235/45 17 tyres fit NC
Patrick Bramston
Postby Patrick Bramston » Thu Apr 29, 2010 4:50 pm
There are some Stock 17x7.5 Evo Rims with Toyo R1R Semi slicks on Ebay. Will they fit under the guards of my 07 NC. I believe the 114.3 stud pattern is the same.. I am looking for track day tyres..Anyone help??
gundam
Postby gundam » Thu Apr 29, 2010 7:40 pm
They'll fit, slight chance of rubbing on tight corners if your car is lowered.
Your speedo will be out with these wheels- wouldnt matter if you plan to only use them on the tracks.
But from memory those 6 spoke Enkei are not that light.... Evo's got plenty of grunt but the NC doesnt....
Patrick Bramston
Postby Patrick Bramston » Thu Apr 29, 2010 8:30 pm
They might be 17x8 not 7.5...Shouldn't make much difference.. What about the offset. I think the EVO rims might be plus 10mm. Is there a danger that they may hit the suspension.
broady
Postby broady » Thu Apr 29, 2010 8:34 pm
Patrick Bramston wrote:They might be 17x8 not 7.5...Shouldn't make much difference.. What about the offset. I think the EVO rims might be plus 10mm. Is there a danger that they may hit the suspension.
At that offset I'd be worried about the guards, I'm pretty sure +10 x8 will give more or similar inside clearance compared to the stock rim.
人馬一体 NA8
6/5/2010
Charlie Brown
Postby Charlie Brown » Fri Apr 30, 2010 9:55 am
Will a 235x45x17 with a +10 offset hit?
YES
I'm running 16x8 with a 50 offset and when fitted with 225x50 R-Specs they just clipped the rear guards, so I did a little rolling to fix the problem. The 225x50x16s are the same O/A diameter as the stock 17" & tyre. The Evo 235x45 is 88mm larger in diameter and the outside of the tyre will be 59mm further out with a +10 offset!!!
I'm not sure what price the EVO's are going for but clearance issues aside I'd steer clear of them for three reasons. Rolling diameter weight and tyres. R1R's are a high performance road tyre not an R-Spec.
Why not do what I did? Buy some 16x8 RX-7 Series 3 wheels (Sailor has a bunch of them; maybe he’ll part with 4 or tell you where to get some). I paid $300 for 4 rims. Then you head off to Gary’s Motor Sport after a Commodore Cup race and get some second hand Dunlop D01s for $50 per tyre. All up $500 for a light weight set of track wheels.
GS
Postby GS » Fri Apr 30, 2010 10:02 am
Arent the standard wheels on an NC something like +60's?? If so, i think +10's would be way too wide.
1989 NA6
Patrick Bramston
Postby Patrick Bramston » Fri Apr 30, 2010 5:54 pm
i have some 16x6.5 Mazda NC Wheels.I bought them to put track day tyres on but I was reconsidering because they are only 6.5 wide. I guess the biggest tyre you could put on them would be 205, that seems a bit narrow...My other option is to drive around the streets on the 16x16.5 and put some 215/45/17's on my 10 spoke original wheels.. Patrick
Charlie Brown
Postby Charlie Brown » Mon May 03, 2010 10:07 am
Fblee wrote:
Will these hit guards with 215 tyres?
Are you talking the Evo rims or RX-7 rims?
You can run up to a 235x40x17 road tyre, on a 8" rim with the correct offset before guard hitting becomes a problem.
The standard NC offset is 55mm. Most aftermarket 8" rims have a max. 48mm offset.
Remember, the bigger the tyre the slower the accelleration. So if youré doing a bigger rim/tyre combo for show, fine. Performance wise you'll be heading backwards.
Randy
Postby Randy » Mon May 03, 2010 5:26 pm
I've been after those RX7 wheels for ages!!!! I've had to settle for some 17 inch light weight wheels.......
Form is temporary.Class is permanent.
Users browsing this forum: Google [Bot] and 2 guests
