roll bar and soft top..
charlie_91
Postby charlie_91 » Sat Apr 17, 2010 11:29 pm
hey i no this has probably been covered but i couldnt find anything..
first of all im thinking of getting the bd roll bar for the na mx5 and was just wondering if this particular bar will eliminate what known as the scuttle shake ?
I want the safety of a roll bar i just want it to be able to get rid of that to..
secondly my softop has been starting to make a bit of groaning when coming around corners and just general driving.. I noticed that it sounds like its moving up and down on the top when im on the highway.. Is there anyway to stop this or help it get better? The latches are quite tight to so im not sure what else i can do.
Any help will be great..
Thanks,
Charlie
Steampunk
Postby Steampunk » Sat Apr 17, 2010 11:53 pm
charlie_91 wrote:first of all im thinking of getting the bd roll bar for the na mx5 and was just wondering if this particular bar will eliminate what known as the scuttle shake ?
Helps considerably for the rear-half (obviously), but most of the scuttle-shake is around the A-pillar area. Front upper strut tower brace helps, and apparently those Boss Frog "Frog Arms" do a better job.
There is a roll bar available locally.
Old Dude
Postby Old Dude » Sun Apr 18, 2010 12:18 am
Don't know about the BD bar reducing scuttle shake, but the local mx5 plus bar definately does :)
MX 5 2001 Grace Green
NB8B
charlie_91
Postby charlie_91 » Sun Apr 18, 2010 11:48 am
yeh im aware of the mx5plus one.. i was just seeing if other people with the bd bar would be able to say if it does and how much by..
any ideas on the softop ?
cheers
NMX516
Postby NMX516 » Sun Apr 18, 2010 12:19 pm
charlie_91 wrote:any ideas on the softop ?
cheers
The bolts both holding the latches on to the roof, and those holding the striker plates, can come loose. You'll need a torx bit to tighten them (avail from Repco). If the latches are too tight then they might be rubbing a bit on the latches. They need to be tight, but maybe 'snug' is a better way of describing it - it shouldn't be difficult to lock the latches in place when putting the roof up.
As for the roll bar - well the mx5Plus one is a much better design than the bd, and attaches to the car a lot better also. As a result, as the others have said, they go a long way to reducing scuttle shake. The only reason I can think of as to why anyone would properly compare both (i.e, design, fitting, attachment points, overall engineering etc) and go with a bd, is price. But then what price is your safety? And there is only a couple of hundred dollars difference at most. You can also reduce scuttle shake by fitting under car braces, and depending on what year your car is, it may not have any, so that would be a good start. There is also the "60mph shimmy" which effects early NA's. The solution to start with is decent wheels and tyres, well balanced. The extra bracing also helps this.
Dweezle
Postby Dweezle » Mon Apr 19, 2010 2:33 pm
Does the TB bar come with Cams Cert? I want the bar for Supersprints etc, and so, want Cams Certification.
Is anyone running these with Cams Cert, and if so how do you go about getting that?
There are a few points i prefer in the TB bar.
Also the mounting points for the harness are a little odd being so close to the drivers shoulders arn't they?
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
de Bounce
Postby de Bounce » Mon Apr 19, 2010 6:04 pm
Although I raised this specifically for Victoria, some of the comments may help.
Clicky
MX5 Plus make a CAMS approved Bar which is not listed on their site.
Motorkhana Video
Postby hks_kansei » Tue Apr 20, 2010 11:27 am
Brown Davis bar does clear the soft top, clears the roof hoop by about 10mm at the smallest point.
MX5 Plus rollbar has more clearance as it sits a little bit lower that BD.
Plus fits under a hardtop, BD is hit and miss, mine does, but there are plenty that dont, depends on install and the car.
as for scuttle shake, after my BD Bar I felt bugger all difference, a little stiffer in the rear, but not enough to bother about.
Postby Mr Morlock » Wed Apr 21, 2010 8:20 pm
so is the consensus that the young blokes are fitting roll bars for safety? If safety is an issue the best thing you can do is get a later model MX5. The Dog Lemon Guide for MX5 1989-98 remarks "that early versions of these cars do not meet current frontal impact standards".
charlie_91
Postby charlie_91 » Wed Apr 21, 2010 8:38 pm
thanks for ur replies..
Ive made up my mind and have spoken to danny.. Roll bar will go in early may when i get my service :D
Cheers guys
Postby hks_kansei » Thu Apr 22, 2010 7:59 pm
Mr Morlock wrote:so is the consensus that the young blokes are fitting roll bars for safety? If safety is an issue the best thing you can do is get a later model MX5. The Dog Lemon Guide for MX5 1989-98 remarks "that early versions of these cars do not meet current frontal impact standards".
ever think that not everybody can afford a brand new MX5?
a proper rollbar is about $800
an NA6 is about $6000 I think.
that's a $6800 car.
NB is about $15000
NC is about $35000 (used)
also, find me ANY car for under $10,000 that meets Current frontal Impact standards?
NMX516
Postby NMX516 » Thu Apr 22, 2010 9:46 pm
charlie_91 wrote:Ive made up my mind and have spoken to danny.. Roll bar will go in early may when i get my service :D
Good choice mate :wink:
Guran
Vehicle: ND - 1.5
Postby Guran » Fri Apr 23, 2010 8:56 am
No argument that NBs are fundamentally safer cars than NAs, but that's not why people fit rollbars. Rollbars are for rollover protection. I'd even recommend a rollbar to NB owners who are looking at tracking their car. The NC has rollover protection already, or so I understand.
charlie_91
Postby charlie_91 » Fri Apr 23, 2010 10:45 am
cheers :) i was always gonna go back to danny but i just wanted to see what was out there first..
de Bounce
Postby de Bounce » Fri Apr 23, 2010 1:51 pm
If it's their CAMS Approved TB Bar, I would be interested in photo's once fitted.
Motorkhana Video
