Is this unusual?
Wivvix
Is this unusual?
Postby Wivvix » Wed Mar 10, 2010 9:15 pm
Hi guys,
In anticipating some suspension upgrade purchases I decided it would be a good idea to check how my car is sitting at present.
Parked on level concrete in the garage I got four different distances from the ground to the top of the wheel arches.
Front Left: 625mm
Front Right: 615mm
Rear Left: 660mm
Rear Right: 645mm
Is this normal? Is this where/what I should be measuring? :?
Is this unusual?
Postby Hammer » Wed Mar 10, 2010 9:34 pm
Which car? As in how old and how many k's?
The varying height could be normal wear and tear on the suspension, or it could be abnormal due to a bent chassis.
But its more likely the former.
Wivvix
Is this unusual?
Postby Wivvix » Wed Mar 10, 2010 9:55 pm
Hammer wrote:Which car? As in how old and how many k's?
95 NA, 190,000km's. No idea about the age of current suspension kit, def no history of it being replaced in the last 5 years.
rascal
Is this unusual?
Postby rascal » Thu Mar 11, 2010 9:14 am
Wivvix wrote:Is this normal? Is this where/what I should be measuring? :?
Yep, pretty normal for a 190k car.
As Hammer mentioned, all car's springs will eventually sag over time, and usually the drivers side more than passenger as it carries the weight of the driver always, whereas the passenger side only sometimes..
Charlie Brown
Is this unusual?
Postby Charlie Brown » Thu Mar 11, 2010 10:51 am
Normal measurements are taken from the centre of the wheel (hub) vertically to the underside of the guard lip.
By measuring this way you eliminate uneven tyre pressure and tread wear effecting the measurement at each corner.
Is this unusual?
Postby 93_Clubman » Thu Mar 11, 2010 1:08 pm
Also, a few NAs seem to have less clearance on the driver's side rear as yours does.
Szemen
Is this unusual?
Postby Szemen » Fri Mar 12, 2010 3:16 pm
My NA8's driver side is wound up higher than the passenger side. ie, its slouched over to the driver side.
Wivvix
Is this unusual?
Postby Wivvix » Fri Mar 12, 2010 7:44 pm
I took some more measurements as per Charlie Brown's (the normal) methodology :lol:
Front Left: 340mm
Front Right: 345mm
Rear Left: 380mm
Rear Right: 365mm
This is stock suspension by the way. I'm not sure if this is normal ride height, but isn't it a bit odd that there's such a discrepancy between the front and rear height?
Is this unusual?
Postby 93_Clubman » Sat Mar 13, 2010 10:05 am
Wivvix, the following text is cut & pasted from:
viewtopic.php?f=30&t=27611
mx5racing wrote:Suspension heights are are calculated via a vertical measurement from the wheel centre to wheel arch.
These measurements are specified by the vehicle manufacturer at the time Aust Compliance is granted. A new vehicle data sheet (NVD1) is issued to the various State/Territory rego authorities. The NA6 NVD1 is known as MAZDA 26 and states the following -
A NA standard is 350 mm front and 370 mm rear. Minimum allowed is 320 mm front and 335 mm rear.
The 100 mm rule is minimum ground clearance for any item (except wheel/tyre).
A lot of aftermarket suspension kits drop the cars lower than minimum spec. .......
Road Vehicle Descriptor (RVD1) sheets replaced NVD1 sheets in 1999. They gave additional information including measurements at full bump and minimum ground clearance (101mm). The last one issued for the NB8B series was RVD1MC-152 issued 20/11/2003.
Benny
Is this unusual?
Postby Benny » Tue Mar 16, 2010 5:12 pm
A good suspension place can easily re-set your springs, and I would say this is the cheapest and easist way out, and then your car will still be stock.
Also, they can re-set the springs to give you a lower ride height too.
