Quick word of warning for those NC drivers running 16 x 8 RX7 rims CB, Paul!
Check them carefully for cracking regularly.
Mine were dye penetrant crack tested before I had them fitted with steel seats and painted.
Checked them today and a visual inspection revealed cracks in 3 webs on the LF wheel after only one day at Wakefield.
RX7 Rims cracking
RX7 Rims cracking
Rob
- Charlie Brown
RX7 Rims cracking
Thanks Rob, that's a bummer.
I always check mine when I take them off and again when I put them on.
The first production run of this rim did have problems with cracking. Later production run didn't.
I think mine are the earlier one, that's why I check them.
So far all's good after about 3 years hard use.
